18” or 19”?
That’s really reassuring - I had a T32 shuttle lowered 50mm on 16inch wheels and it was awful...learnt my lesson. The dealer is going to lower mine 30mm on delivery - over the moon that yours is the same.
yes mine was done by dealer before I picked it up too so you'll likely have the same set up. enjoy
I have a 6.1 4 Motion van on order and have been looking at 18" wheels but the Bolt holes in the wheel look small , I would think only a 18mm socket would fit in.
Could someone tell me the head size of the wheel bolt please.
Not the thread the head.
Aftermarket and none standard oem wheels are normally 17mm bolt head different to the 19mm from oem vw wheels..
I’m putting spaces on my cantara wheels so need extension bolts, my standard bolts have the loose collar / seat, would it matter if my extension bots are a fixed seat rather than movable / loose? Cheers
It’s doesn’t matter. You can use either. Personally I like to keep the OEM style with that collar. Normally you can buy the set bolts and spacers.
