Hello everyone, Im taking delivery of a new T6.1 Caravelle 199 Exec next week. I was looking around for 19 inch wheels to upgrade from the standard 17's. Got talked into buying a set of 19 ET40 9.5j wheels since i liked the design and the gunmetal colour matched the Reflex silver paint. 8.5 j wheels for the same design were out of stock.
Could anyone share some knowledge on the right size tyres for these wheels please. Seller advised on 255 40 R19 for the 9.5j rims?
I am new to this forum and have never used a similar vehicle.
Are you lowering as well?
No i'm not thinking about lowering, don't have a clue about vans, driven cars all my life. Im just worried about the 9.5j wheels all around. The seller said it would be alright hence asking for help and advise.
Hi HUW, No im not planning on lowering. Just worried about 9.5j ET40 wheels all around. kindly advise
They’ll definitely be OK on the rear, but I would expect a little bit of poke at the front. The outside edge of the tyres will probably be just outside of the wheel arch at the top. Not a problem if you are running at standard height.
As has been said, you’ll get a bit of poke on the front.
If you do want to lower in the future they will limit your options. It would not be ideal for me, but we all have different needs.
I use an ET35 8.5j for the front with a 245 tyre that allows me to lower to about 60 mm without any issues.
Hi what’s the best of-set and rim size for 19inch wheels found some but they r 8j and 45et thanks kirk
I'm no expert but that sounds about the same as Amorok 19's which imo fit great on the front and look their best with 10-15mm spacers on the rear.
In theory the face of an 8J et45 wheel will sit around 22.7mm (3/4"ish) further under the arch than an 8.5J et35.
My opinion would be 8.5 with an ET40 offset and if your is a T28 or 30 a 245 - 45 - 19 102 tyre or 255 - 45 - 19 104 if you've got a T32. Any where in the 35 - 45 offset range will work fine though unless you're particularly low in which case a higher offset will put the wheels further under the arch.
Thanks for your reply its lowered 50mm i will look for some 8.5 found the wheels I want but they r 8j et 45 would like to run a 45 profile tyers it’ a minefield picking some wheels a lot of places r out of stock as well
I have 19s on et45 and in my opinion they could do with at least 10-15 spacers on the front and more on the back, which is annoying because I specced them at et45! :mad:
Lol how low r you what would you go for if you could change don’t fancy spacers if I can help it thanks kirk
It’s pretty low although I’m not sure exactly how much drop as it’s had a few different setups from new. You can see from the photos how the tyres look (255/45R19).D4DE9B37-C58B-4B2B-B187-73DAF431AAA9.jpeg8BBD0B20-C4C5-41F0-A685-17465449DDDA.jpeg
