Leighton vans are generally all lowered (which may impact the ride as well as the 20" wheels) so bear that in mind.I think I’ll hire one of Leighton Vans for a day with the 20s before committing the money.
I have my Caravelle lowered on staggered velare 20 wheels with 265/40 tyres. It’s on twin adjust projekt comfort coilovers that aren’t all the way down.
The arch lining has been modified slightly by removing screw at top of arch and folding liner under tab. It’s fine on a roads and B roads mostly but if I hit a ‘bouncy’ undulation in the road it will catch the arch enough to make me cringe and my backside to clench!!
Question is - is there anything else I can do to mod or do I need to raise it? Images of vans on 20’s wound all the way down suggest it’s doable?! Thanks
I'll second @Tourershine comments, those fronts do look like the width/offset isn't quite right for you. You should be able to run at the height you are with a 265/40. I have done so myself in the past and my van is lower than yours at the time. Of course, changing the front wheels for ones more suitable is a more expensive fix than raising your ride height a little.I have my Caravelle lowered on staggered velare 20 wheels with 265/40 tyres. It’s on twin adjust projekt comfort coilovers that aren’t all the way down.
What widths are your fronts? They look either a bit too wide or the offset is too far out.
Not too crazy 8.5 on front and et 35 I believe...
Are the dampers/shock absorbers, within the twin adjust projekt comfort coilovers, built by Koni for the Twin Project company? If so, are the dampers adjustable for damping?
Dropped vans are really not my thing but I understand, it has something to do with aesthetics? That the appearance is the the most important requirement? Then achieving the best handling and ride characteristics is always going to be a difficult and a compromised task. As Jog has stated, razing the height, will give more suspension travel and if the damping is adjustable, then, stiffening one click, might encourage the dampers to get a grip on things. You could try that. Perhaps one thing at a time and noting what the difference might be, taking note and so on.
Same as mine, but I use a 245/45 tyre. 265 is too wide for an 8.5” rim in my opinion.Not too crazy 8.5 on front and et 35 I believe...
Nothing wrong with those figures.
This is correct.Not too crazy 8.5 on front and et 35 I believe...
This is correct.
We fit this size all the time with that tyre size too, and you can usually go max on standard coilovers without issue - a Caravelle is heavy so will always sit lower. Have you seen underneath exactly where it’s rubbing. Can you get a picture - might need to go a bit more aggressive with your modification.
The fact you’ve already done the modification is odd you are still rubbing. We get less issues with this size than the 275/35.
