255/45 gives you a bigger diameter than 265/40 and will rub more. It’ll also throw your speedo out by too much. 265/40 is the right size for T32. It might be OK and not rub. How low are the springs? -50mm? Usually only need the heat gun past about 60mm lowering or so.Will 255/45 not fit without a heat gun then?
