2006 T5 2.5 AXD Engine Not Starting California Camper conversion.
re reading this thread, the VW dealer cleaned tank and fuel pump and tested. THEN refitted to vehicle. Could be red herring but did they test it AFTER it was re-installed. I would like to think they have some intelligence rather than just following a diagnostic script.
Looks like as VW sells cylinder head as a fairly complete package.
Also it seems it will be soon on a clearance sale...
Per AXD (5-cyl 96kW variant) engine workshop manual AXD doesn't have DPF.
Also wiring diagram for AXD engine doesn't have G450 exhaust pressure sensor suggesting no DPF.
Before my T6 I had T5 & AXD engine and definitely no DPF.
However, DPF was onboard on T5 BNZ engine (also 5-cyl 96kW), from January 2006 onwards, as well on T5 5-cyl engine BPC (128 kW).
Well, it seems that there was a retrofit kit for DPF available.
Probably worth asking the guy who did the engine rebuild if a new head was installed then, especially if it is a known issue and repaired at VW's cost?
Not totally impossible - but as above would still expect run - at least on a few cylinders if not all.
Anyways, the above statement bothers me - there is no mention that this test have been redone. Neither it's not mentioned that do the injectors get the firing pulses? If the injectors receive the pulses it would eliminate nearly 100% issues on ECU side and it's accessories - immobilizer, sensors, etc. Need to measure both voltage and current.
Well, modern ECUs would do the analysis in their diagnostics but I'm not sure AXD ECU was at that level.
mmi: thanks once again.
I will be asking VW to run another diagnostic to ensure the injectors and pulsing both voltage and current.
my personal view, even if the head is cracked I'm sure it would still run, albeit rough, granted
Thanks.
Reactions: mmi
manfrotto
Ron purchased a full recon engine from Ivor Searle. it was fitted by a local garage 4 years ago, and has done a faultless 37,800miles. that was until this current issue arose. The thing I still cant get my head around is, it was running perfectly less than 45mins before it failed to start.
manfrotto
Which to me is a electrical component failure
Contact these guys and ask got a price to remove your immobiliser, cheaper than buy a ECU with immobiliser already off
Just a note: it's a job for an oscilloscope to catch the pulses as the fuel injection burst is somewhere in 1-3 milliseconds at about 170 millisecond intervals for each cylinder (when cranking at 200 RPM).
It would be beneficial/essential to have an oscilloscope with a decent memory buffer to record a sample (of several pulses) in one go. Otherwise likely to see nothing.
mmi
Please see below from the VW tech
mmi
See attached taken from an email I received from VW on 8/7/24, this was before they sent the injectors away for testing, then advising it needed a new set of injectors.
It looks as though they used an oscilloscope to test the original injectors and timing.
Reactions: mmi
Yes, obviously the voltage was measured. Anyways, I'd like to believe the ECU monitors that the injectors ingest proper amount of current and would throw a fault code otherwise. That's what VW SSP 304 states for the ECU - page 11 in https://procarmanuals.com/pdf-online-vag-ssp-304-electronic-diesel-control-edc-16/
Back to square one - anyone sniffed the exhaust after/while cranking - any diesel smell?
manfrotto Hi.
VW have not managed to get it running inspite of all the new bits they’ve fitted and the other jobs they’ve done.
I am due to pay their invoice £4.7k tomorrow and arrange recovery back to Ron’s next Tuesday which will be 6month and 1 week since it was delivered into them.
The next thing they wanted to try was to replace the cylinder head, at around £2.5k. VW would not guarantee it would cure the problem. So we agreed to draw the line under it.
I don’t really know the next steps, apart from getting it back home to Ron.
Regards
Derry
manfrotto Hi.
Regards
Derry
It’s probably worth more being sold as a non runner, someone else will take on the challenge of getting it running. You could get an idea of what it is worth in parts if you look at eBay prices but it is the hassle of stripping it and having somewhere to do it.
Thanks PhilH
Yes you’re probably correct, and like you say save having to pay someone to strip it into parts. Not sure what a 2006 high roof T5 California is worth, MoT has expired whilst it been off the road which doesn’t help.
