2016 T6 102, Stolen / Recovered. Charging Fault [Resolved]
could Have been leaking possibly due to been stood or simply thrived on a bit of upsell what did they say was the reason for replacement
No reason, I asked but the service desk could only tell me what was written down on the job sheet, and couldn't offer an explanation. Which is why I've told them I'll call back in the morning. Hopefully I can speak with the technician
Because they rarely have the staff capable of sorting jobs like this and never the inclination.
Not sure that makes any sense. They have access to VW technical, they are VW trained by the manufacturer, and time/money is their inclination.
VW specialists wouldn't look at it, they recommend main dealer. I couldn't resolve the fault myself, so what other choices are there?
Hey buddy , sorry yer not having much luck with your van .Honestly sounds like vw haven't been able to trace the fault but because your van is 4 years old then it's just flagging up that water pump and belts need done ,I would honestly look for a independent vw specialist and not go to vw directly especially if you are out of warranty ,just my opinion as from my experience independent garages have alot more knowledge than main dealers and are cheeper , it sounded like once you had sorted the charging issue with you van that the Glo plugs were getn sufficient power to work correctly and that fault had cleared , could be long shot as it's a different vehicle but my friends T5 battery was on its way out and he was having starting issues and turned out there was not enough power in the battery to heat the Glo plugs correctly , is the van still starting correctly and has the battery been tested ?
It's had a new battery, charging problem is now resolved, it's just the glow plug wiring fault that keeps coming up on the scan, and it takes a while to start on a cold morning.
Specialist said it would be cheaper in long run going to main dealer as they'd have to start replacing parts to eliminate potential faults whereas the main dealer should find the fault.
They can remove the ECU and bench test it, and if necessary re write it apparently. That's main dealer only.
Looking
I can't see the water pump replacement fixing your glow plug issue and regarding the egr flash I believe they ment flush possibley?. It honestly sounds like it's not getn enough voltage to heat glow plugs correctly as it says intermittent fault , ano you said you replaced the battery but did you code the new battery into vcds at the time you replaced ? Ano it's been working fine since you fixed the fuse but I believe the reason you have to code the new battery in is so the voltage regulator knows the amps in the new battery at the time of replacement ,am sure there is a few links to this on here , also just to check the battery is working correctly have you tried charging battery fully and then tried to start ?. When charging battery with battery wired up to van you have to also use a separate ground point for negative connection as the voltage regulator is connected to the negative terminal , I normally use the torq screws for headlight as a negitive point
Have you checked the r distances of the glow plugs, also don’t rely on the battery starting the vehicle that it’s a good battery
Glow plugs have a separate fuse in the e-box under the battery, I think I mentioned earlier, check that and check the terminals are tight, re-seat the glow plug relay that's in the e-box as well.
Looking
Yeah, the battery is new from TPS, and I coded it using VCDS.
Went through all the suggestions on here thoroughly. All fuses were good, I checked continuity between cables to / from glow plug relay etc. Checked for good connections on glow plug control module. Got as far as I could with my capabilities.
To be honest you have did more than what I would have attempted to do and probably did more problem solving than what vw would have did , looking back at the thread you said that you fitted a new battery and that went dead on way home obviously because you had a charge issue that you fixed so you no longer have that problem but is this the same battery you are using at the moment ? If so then if you haven't already I would fully charge the battery and reset fault codes then go through start procedure again and see what codes you get .just to rule out the the battery is not at fault ,a believe in yer logs it states that when yer glow plug faults were registered the voltage was around 11.7volts but not sure if that's when you are also cranking the engine over or if that is just the 2.5 secs glow plug heat up , be good if enyone can shed some light on if the voltage of 11.7 on the logs is sufficient
All 4 plugs shows same voltage and 2.5 secs on yer logs, I unfortunately don't have vcds to compare
I'm not sure what voltage should be listed there, but the battery is definitely fully charged now.
Annoyingly, VW just called to say one of the service team has tested positive so they have now closed the service department entirely until further notice! So my van is now stuck at VW. Luckily I don't need it but I feel sorry for anyone else who relies on their van for work!
(Most likely a false positive test since the false positive rate is 90 odd % )
Don’t rely on be dealers I had issues with one yesterday eventually had a master tech ( oooo) idiots tbh not only did they not like being put right they did not check the basics resulting in them wanting to and insisting on fitting a new brake light switch under warranty as I had done one couple weeks ago, I got the whole he’s a master tech which does not wash with me five mins of looking today and found the fault they couldn’t , it didn’t go in for it they semi caused the issue,
