2nd row bench to 3rd row
Phil1878
Evening all, I'm thinking about moving the bench in my kombi to the 3rd row. Has anyone done this before? I've seen conflicting posts saying you need different seat belts/extender bar.
If you need different seat belts I may as well get 4 new brackets and leave the 2nd row seat belts in place and have the option where to sit. If its the same belts I may as well take them out. Thanks in advance
Thanks. I'd probably look at moving the belts and brackets back. Can't see why I'd ever need them back in the 2nd row. No how do I get the floor brackets out without dropping the fuel tank
Not certain it’s possible without dropping the tank. You only have four to get to rather than eight or twelve though, so if you don’t get a better answer, I suggest getting under it and checking. You might be able to get to the four middle ones more easily.
A few youtube videos and a bit or crawling under the van looks in order. Just need to finish deep cleaning it, haven't had much chance with the weather
