Found these ...
big-difference.com
cs-batteries.de
www.forster-batteries.de
Basically drop in batteries that fit the same space as the AGMs currently in my T6.1
So ... been toying with fitting LiFePO4 batteries for a while, but obviously from the factory it is set up with 2 x 75Ah AGM leisure batteries and a VW charger and smart alternator, also set up for AGM batteries. There are shunts on all the batteries and the camper unit monitors how full they are (obviously knowing they are 75Ah AGM batteries) ... so bit of a headache to integrate into the VW system and replace the AGMs with Lithiums .... but I think I have a solution and would be grateful for any observations or mistakes in the following diagram. Everything to the left of the blue dotted line is VW original and the right are my additions.
When parked, the solar will charge both the Lithiums and the AGM starter. (Starter Trickle Switch set to "On")
When on Shore Power, the VW charger will charge the AGM starter because when the charger runs, it closes the isolation relay. The VW charger will also charge the Lithiums via the DC-DC (Starter Trickle Switch can be "Off or "On" but will have no effect)
When engine is running, the DC-DC and the MPPT will charge the Lithium batteries. (Starter Trickle Switch best set to "Off", On will fight the smart alternator, but I have this at the moment and it has no discernable effect other than producing a much bigger solar yield.)
The position of the switch isn't critical and the battery protect will protect the lithium batteries from discharging when there is not a charging source present.
That is my thinking ... anyone notice any glaring errors?
Will take the plunge this summer and see how the Camper Unit copes with this setup and how it reports the battery status. If it is too confused then I will put in Victron shunts and monitor the leisure batteries with a battery monitor.
Future projects are a CerboGX OS running on a Raspberry Pi, and an Inverter upgrade.
VANVOLT LiFePO4 Lithium Batterie 12,8V 100Ah DIN H6 Arctic BMS mit Bl, 729,00 €
Top-Qualität nach europäischen Standards Wir als Hersteller im Sinne des Gesetzes übernehmen die Garantie dafür, dass dieses Produkt bei sachgemäßer Verwend
Lithium LiFePO4 Caravan VW T6 12V / 100Ah | CS-Batteries
Lithium LiFePO4 Caravan / Wohnmobil VW T6 Untersitz-Batterie 12V / 100Ah ✔ große Auswahl ✔ bester Preis ✔ schnelle Lieferung ➤ sicher bei uns bestel
12,8V Lithium 100Ah LiFePO4 Premium Batterie | 200A-BMS-2.0 | Ducato
12,8V Lithium 100Ah LiFePO4 Premium Batterie | 200A-BMS-2.0 | Ducato Ford PSA VWT6 TGE | 1280Wh | IP67 in PREMIUM-VERSORGUNGS-BATTERIEN, PRODUKTE
