ABS/Traction control lights still on
dinz_dinz
Hi guys, looking for help. I have a ABS/traction control light on with no fault codes. I have a topdon scanner it didn’t show errors and all 4 wheels displayed accurate speed readings. I’ve been to a local VW specialist that has been recommended on various forums. Due to no faults they tried to reprogram the ABS module but it failed. They advised me to get a second hand ABS module and have it fitted. I got an ABS module off Ebay from another VW T6. It was programmed successfully but when the mechanic bled the brake system using a professional scanner the bleeding process failed to be fully completed. The mechanic thought that something must be wrong with the used ABS module and advised me to get another one and repeat the process. He said that he hasn’t seen anything like this before. Just thought to ask the community if anyone had similar problem with ABS/Traction control. Can any other components go wrong? I doubt that another ABS module will solve the problem
Sorry I should’ve said LIGHTS. The three lights are on. No fault codes whatsoever. The mechanic plugged VCDS and I plugged my own TOPDON scanner with no success IMG_6182.jpeg
  • Wow
Now that's interesting :speechless:
Could you please post the VCDS Scan?
Could you please make blockmap -files of controllers 01-Engine, 03-ABS, 09-Central electrics, 17-Instruments
a) a set with ignition on (engine not running)
b) a set with engine running
I'm hopeful these would give some hints to narrow down the cause/reason behind the lights
How-to:
VCDS > Applications > Controller Channel Map >
For "Single controller address" - 01, 03, 09, 17 (a run for each address)
Tick/fill boxes as above and click Go.
VCDS flashes screens for a moment (when finished hit "Done, Go Back") and there should be files blockmap-XX-... in folder C:\Ross-Tech\VCDS\Logs\....
Thank you for trying to help. Really appreciate it. I’ll try to acquire the data and post it here shortly
How-to:
How-to:
Here is a VCDS scan:
Code:
Tuesday,24,December,2024,21:02:03:07256
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4643.5
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WV1ZZZ7HZJX024763   License Plate: DU18JJX
Mileage: 185090km-115009mi   Repair Order: 1
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZJX024763   Mileage: 185090km-115009miles
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4047
   Revision: 23002001
   Coding: 00114014432401090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
   ROD: EV_ECM20TDI03004L906056KA.rod
   VCID: 76B23E85D846F83A757-8022
   VINID: 9E606AAAA1D8A9AA000841C60CA2A5195A
1 Fault Found:
31103 - SCR NOx Catalyst Bank 1
          P20EE 00 [01100100] - Efficiency too Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 184707 km
                    Date: 2076.01.30
                    Time: 23:48:06
                    Engine RPM: 2229.25 /min
                    Normed load value: 51.0 %
                    Vehicle speed: 94 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 12 °C
                    Ambient air pressure: 1020 mbar
                    Voltage terminal 30: 14.695 V
                    Air mass at air mass meter 1: 154.8 kg/h
                    Outside temperature sensor 1: B1: raw value: 11.5 °C
                    Mass airflow sensor 1 bank 1 airflow: raw value: 584.3 mg/stroke
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.13 %
                    NOx sensor before SCR cat conv: offset correction factor: 0 ppm
                    NOx sensor after SCR cat conv: offset correction factor: 97 ppm
                    Reducing agent quality sensor: urea concentration: 0.00 %
                    Reducing agent quality sensor: raw temperature value: 0.0 °C
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 62428000000556
   Coding: 517E4098256484828A7C027CA48521E679F100
   Shop #: WSC 131071 1023 2097151
   VCID: 3FDC9BA1B7FC7972661-806A
No fault code found.
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 26121713470246
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA226A5F076B07A2D7-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: 73B40791CB34ED12529-8026
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 035180735
   Coding: E0A4303A0A212033002009742C2B8C540F80708F60444D60330400220800
   Shop #: WSC 35110 377 08192
   VCID: 2B04DFF15304F5D2DA9-807E
   Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  004 0653
   Serial number: KU0KU024011880240311
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU025011880250592
   Coding: 0400A0
1 Fault Found:
03304 - Response Closing Status of Rear Right Door
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 190
                    Mileage: 180504 km
                    Time Indication: 0
                    Date: 2019.01.29.
                    Time: 00:44:33
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261801100873
   Coding: 10800D
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71B80D99B128DF02A05-8024
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1601180442B22C
   Coding: 00004000FE0779
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: 3632FE8598C6B83AB57-8062
1 Fault Found:
1058 - Databus
          U1123 00 [00001001] - Received Error Message
          [FAULT_CIS_ECD_NOTAVAILABLE]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 180473 km
                    Date: 2024.09.06.
                    Time: 05:31:23
                    Control Module temperature: 43 °C
                    Voltage terminal 15: 13.3 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
   Component: VW10Airbag021 010 0018
   Revision: --------    Serial number: 003EK000D99P Dataset Number: 7E0003V____ 0905
   Coding: 000000000000000000000000000000003231
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D20E1A9BDF06B6274D-8068
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Serial number: 00000000000000
   Coding: 450B010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
   VCID: 3A2AEAB5ACDE5C5A51F-806E
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042305
   VCID: 688E60FD82721ECAF7B-803C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1107
   Serial number:
   Coding: 000000
   ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
   VCID: 6A8A1AF59CFE2CDAE1F-803E
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     056 7205
   Serial number: 03021800010638 Dataset Number: V03935266VJ 0001
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E02D6E5609680FAFD7-807A
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030B7A73
   Shop #: WSC 09999 999 999999
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 7588570000180214025E
1 Fault Found:
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 7
                    Fault Frequency: 47
                    Reset counter: 228
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2019.03.17.
                    Time: 10:11:28
End----------(Elapsed Time: 01:18, VBatt start/end: 12.3V/12.3V)-----------
These are blockmap files
  • blockmap-01-04L-906-056-KA_WV1ZZZ7HZJX024763-20241224-2052.CSV
  • blockmap-01-04L-906-056-KA_WV1ZZZ7HZJX024763-20241224-2047.CSV
  • blockmap-03-7E0-907-379-P_WV1ZZZ7HZJX024763-20241224-2054.CSV
  • blockmap-17-7E0-920-970-S_WV1ZZZ7HZJX024763-20241224-2055.CSV
  • blockmap-09-7E0-937-090-C_WV1ZZZ7HZJX024763-20241224-2054.CSV
  • blockmap-09-7E0-937-090-C_WV1ZZZ7HZJX024763-20241224-2049.CSV
  • blockmap-03-7E0-907-379-P_WV1ZZZ7HZJX024763-20241224-2049.CSV
  • blockmap-17-7E0-920-970-S_WV1ZZZ7HZJX024763-20241224-2051.CSV
Thanks - interesting....
The dash (17-Instruments) reports the three warning lights active as
so not a surprise.
Anyways, it seems that the origin of the lights is the ABS controller.
So, the ABS is actually quite happy with the situation - no faults - now just to need to figure out why the ABS has decided to put the warning lights on.
What were the faults initially?
Could you please make another set of blockmap -files of the following controllers: 03-ABS Brakes, 04-Steering Angle, 17-Instruments
a) engine running, steering wheel centered (straight ahead)
b) engine running, steering wheel turned 90 degrees to the right
c) engine running, steering wheel turned fully to the LEFT (no need to hold - just leave where it stays)
Something strange (=different than mine) in ABS
Please check the fuses
SB16, SB17 (fusebox by left headlight)
SC32, SC51 (centre fusebox in cabin)
Thank you for looking into that. I’m really grateful to you
Same three lights were on the dashboard but no errors/faults found via diagnostic tests performed by the mechanic.
I’ll check the fuses and get blockmap files asap. Now I’ve got my own VCDS
Good evening gents, here are a new portion of blockmap files that were requested
  • blockmap-17 straight-7E0-920-970-S_WV1ZZZ7HZJX024763-20241230-1725.CSV
  • blockmap-03 90degree right-7E0-907-379-P_WV1ZZZ7HZJX024763-20241230-1726.CSV
  • blockmap-04 90degree right-6R0-959-654_WV1ZZZ7HZJX024763-20241230-1727.CSV
  • blockmap-04 full left-6R0-959-654_WV1ZZZ7HZJX024763-20241230-1728.CSV
  • blockmap-17 full left-7E0-920-970-S_WV1ZZZ7HZJX024763-20241230-1728.CSV
  • blockmap-17 90 degree right-7E0-920-970-S_WV1ZZZ7HZJX024763-20241230-1727.CSV
  • blockmap-03 full left-7E0-907-379-P_WV1ZZZ7HZJX024763-20241230-1727.CSV
  • blockmap-04 straight-6R0-959-654_WV1ZZZ7HZJX024763-20241230-1725.CSV
  • blockmap-03 straight-7E0-907-379-P_WV1ZZZ7HZJX024763-20241230-1725.CSV
Thanks. Well, we can exclude steering angle sensor being the culprit.
I believe the next step is to make ABS see "terminal 15" power - thus in the blockmap data to turn the below to "ON"
I checked quite a few T6 blockmaps and everyone has "ON" there
Per wiring diagram the mentioned fuses power the ABS but obviously the "terminal 15" power doesn't reach the ABS - most likely from fuse SB17 (5A) which feeds ABS connector/pin T38a/6 (as marked terminal 15), thin 0.5 mm² black wire.
Thank you so much for checking the files and explaining the connection between SB17, Terminal 15 and ABS.
I’ll try to unplug the 38-pin connector from the ABS module, check voltage on pin 6 and feed another ABS-fuse wire.
I have tried to unplug the connector in the past but space was too tight.
Anyway, I’ll definitely post updates here how things are going
Good morning guys, yesterday I checked pin 6 on the 38-pin connector. The black wire SB17–>pin6 didn’t have continuity. I replaced it with an identical wire. It’s got continuity now. The old wire looked corroded inside. However, a scanner still shows Terminal 15 - off. That’s really weird and confusing. There’s a positive effect though — I don’t get the message on the dash ‘Brakes! visit workshop’ (don’t remember exactly what the message was). But the three lights are still on and a bip when switching on the ignition.
Thank you @mmi for giving this topic attention again. Really appreciate that. The first time when I replaced the wire I tested it for continuity but didn’t test for voltage because the fuel filter was off the fuel lines. This was bothering me that I should have tested. So I went down the rabbit hole again but this time I checked the voltage on pin6 of the 38pin connector. And the normal voltage was present. I inspected the male pins of the ABS module for corrosion etc and there was none. I sprayed contact cleaner in the female pins of the 38pin connector then put the 38pin connector back on the ABS module and moved it by hand back and forth. When I turned on the ignition ABS lights were gone and terminal 15 is back ON. However the ASR/ESP indicator light is still on. My scanner is reading a couple of new codes atm. I ordered more terminals/pins for another connection that I broke when I was moving things around (LIN generator wire on the battery monitor control unit). It will be delivered tomorrow so hopefully will get into it within a couple of days and post an update here. Sorry for the unprofessional scan. Although I have got a VCDS now I haven’t got a laptop yet. I borrowed a laptop but forgot to get a full general scan. This is what I’ve got now on the blockmap-03: IDE02271… CAN output signal status - Start-up status - DEGRADED. on the blockmap-01: IDE06704… ESP system error - YES (it was NO on the previous scans posted before). I was extremely gentle with the wiring but must have messed something up. I’m waiting for a cable tracker as well.
  • blockmap-01-04L-906-056-KA_WV1ZZZ7HZJX024763-20250126-1306.CSV
  • blockmap-03-7E0-907-379-P_WV1ZZZ7HZJX024763-20250126-1304.CSV
That's excellent result :thumbsup:
Hmm... interesting... I'm sure you noticed also the other changes - I guess they all are connected...
Thanks for sharing all the data :thumbsup:
IDE02271-MAS11590CAN output signal(s) status-Start-up statusdegraded
IDE04443-IDE02241Slip control system sensor-Lateral acceleration sensor 1Malfunction
IDE04443-IDE04449Slip control system sensor-Rotation rate sensor 1: Z-axisMalfunction
Did you try to clear all faults and perform steering wheel full rotation clockwise and anticlockwise?
Assuming no other issues, this light should go off after a short test drive (obviously if it's safe to do so).
