Hi, I love this Forum and it has been a wealth of information for me since getting my van. After a lot of reading over the last few days I think I have over filled my AdBlue but would be interested in your thoughts and to sanity check my thinking.
I've owned the Van (2018 T30 SWB Kombi 150 Manual) for 18 months as a day van, when I bought it the garage sorted the AdBlue and I haven't really thought about it until it got down to 700 miles to go on Sunday and the readout said 2 Gallons (9.09 Litres) Minimum and 2.75 Gallons (12.5 Litres) Maximum.
So following advice to only put in what was being asked I bought 10 Litres from B&Q. I put in the whole 10 Litres, switched the ignition on and waited for 30 seconds, fired up and no change! I've since driven 128 miles and today it's showing 550 Miles to go and the Amber fill warning is on and the EML has lit (P203B00 - Reductant Level Sensor Circuit Range/Performance).
So after a lot more reading on here and hooking up ODB Eleven yesterday when I returned from work to look at the live data I noted:
Engine Module:
Reducing agent fill level sensor - 0mm
Reducing agent tank volume actual value calculated - 3.626L
Remaining vehicle distance until reducing agent deficiency - 956.492km
Dashboard Module:
Urea operating range - 600km (presume this actually means miles as 600 Miles is approximately 957km)
So my thinking is despite it saying fill between 9 and 12.5 Litres, it actually had just over 3.5 litres left in the tank and when I added 10 Litres it's overfilled and that's why the level sensor is reading as 0mm because there is no air gap to allow a new measurement?
After work today and completing a further 56 miles
I am seeing:
Reducing agent tank volume actual value calculated - 3.533L (a reduction of 0.093L) so I am thinking rough maths I need to drive another 300ish miles to reduce the real amount in the tank to below 13 Litres?
I have attached both days logs for reference.
Does this sound correct ie. I've overfilled it and confused it? If only I knew before filling it that I could get a tank reading from the Engine Module
and if my thinking is correct given that I now have the warning sitting at 550 miles until no start, do I just keep driving and hope it resets or should I get under the tank and drop the pipe to get say 4 to 5 litres out and then have a drive to hopefully force it to register?
I'm presuming P203B00 is related to the overfill/incorrect value and that I can clear it down?
Engine Module:
Dashboard Module:
I am seeing:
