1200 miles - I’ve got to drive 60 miles today - if that doesn’t do it I guess dealer - boring, over complicated engineeringOthers have reported it sorting itself out whilst driving.
some have had software updates at the dealership.
what range do you have?
It’s easy and fine when it works - it’s just it doesn’t actually work as it should for a significant number of us. You’re in the lucky majorityAfter all the horror stories about this I did my 6.1 last week for the first time.
It said put 10.5 Litres max, I bought 2 x 5L containers, put most of it in before it was brimmed (Right to the fookin top!!!) I couldn't actually get 10L in!
I was super cautious as people were advising not to overfill it and I thought I has messed it up. So I switched the van on, waited... started it... went for a drive... done, all sorted.... what was I worried about!
It’s easy and fine when it works- it’s just it doesn’t actually work for a significant minority of us. You’re in the lucky majority2019 T6 - Warning flagged 600 miles left.. fill with 2.75 gallons min, 3 gallons max.
Put 13 litres in, ignition on for 30 seconds, then turn over.. MFD updated.. 6000 miles left.
Makes you wonder why we couldn’t have had a gauge with a needle rather than all this computer digital readout nonsense doesn’t itYou are not alone - I tried to top up my T6 last week when it flashed up, I carefully measured out less than was required and it it overflowed also! Thankfully updated on the dash fine, but left me perplexed as to what had gone wrong.
Did you get anywhere with this? I have exactly the same problem and and now down to 350 miles before engine won’t start.Hi all
I have a 17 150 t6, 650 miles ago I topped up with adblue as directed on my dash display, yesterday I drove my t6 and I had 5500 miles adblue range.
Unfortunately suddenly the Amber adblue warning beeped and the display said 600 miles till no start.
I topped up with adblue, knowing that I should have plenty, I managed to get 4 litres in the tank, leaving a little room so's not to over fill.
I turned ignition on for 30 seconds to reset the adblue but it doesn't reset and and continues to say 600 miles till no engine start, at no time while all this was going on did the display recommend how much adblue to put in.
When I topped it up the first time that I already stated the display advised me on min and max to enter, I'm lost, any ideas or help would great or do I just need to take it to a vw main agent.
Thankyou in advance
Thanks, turns out you’re right. I was told it didn’t when I bought the van (2nd hand) and the service centre seemed happy it was possible I didn’t have VW assist if it had been bought from a discounter.All vans get VW CV assist for the warranty period.
That's 3years.
So you will be covered to 2023.
Call them up.
Thank you.more info here:
DPF Regen, Yellow Light & Adblue - Whats It All About? -
DPF Regen, Yellow light & AdBlue - Whats it all about? - The DFP light is becoming a more apparent issue with modern diesel vans, unfortunately, it’s a fact of modern diesel life. what is a DPF? Diesel particulate filters (DPF) are very effective in cutting emissions, trapping even the...www.t6forum.com
and here:
ENGINE & SERVICE:
- T6 Common Faults & Problems - - Check Here First -
- Vcds And Carista Fault Codes
- T6 Service Intervals & Inspection, Flexible & Longlife
- Check Oil - Warning, Check Your Fluids ! (what Oil?)
- Service Parts List - What Goes Where -
- Dfp Regen, Yellow Light & Adblue - Whats It All About? -
- Mpg + Fuel Economy - What Mine Does -
It’s barely been driven but did wait the 30 secsHave you driven the van since topping it up, it can take sometime to register the new amount. Did you wait the 30 seconds with the ignition on before starting it?
