Agreed, sounds like a planAs I see it my next plan of attack will be check the adblue injector is functioning and check adblue in the tank with refractometer does that sound about right ?
Will have a go at that asapIf interested to log NOx sensor with a couple of related parameters (exhaust temps, air flow, etc)
VCDS > Select Control Module > Engine > Adv. Meas. Values
tick "Group UDS Requests by 7" (greatly enhances sampling rate)
then tick the following data channels
IDE00021 Engine RPMIDE00075 Vehicle speedIDE00347 Air mass: actual valueIDE04090 Exhaust temperature bank 1IDE04098 NOx-sensorIDE07757 Exhaust recirc.valve 1 bank 1: posit.feedback - Actual valueIDE09009 NOx sensor after SCR catalytic converter: supply voltageIDE10241 Reducing agent pump module relative press.: calculatedIDE10248 Reducing agent supply pump: offset factor calculatedIDE09017 NOx sens.dwnstrm.SCR cat conv: NOx conc.IDE10817 Lambda value at inlet of particulate filterIDE11219 Reducing agent inj. quantity: spec. value
Click on Log to start logging.
and take the van for 30 minute drive. Disable Stop/start. Preferably some driving at no faster than 50-60 mph.
The result file will be in the ...Logs -folder
I'm definitely interested to see if (or not) the NOx sensor doesn't wake up. Actually by recording also AdBlue injection (commanded) I'm hoping we could see something about injector behaviour. Thus my working theory is if commanded (specified) values (pressure, injected quantity) go up without reduction of NOx levels - it would indicate clogged injector. However, never had a chance prove if this theory actually works.
Where did you find the engine flags above mateThank you very much!
Quite a discrepancy in remaining AdBlue range what Instruments sees (450 km) vs. what engine reports (9635 km).
Also marked with red/yellow other not normal values - obviously the AdBlue Warning is stored here.
Interesting why/how the Instruments has taken a separate path. Possibly the "flags" below from engine are the cause
ENG110382-ENG20519 SCR inducem system status-deviation of reagent consumption CONSUMP_DEVIATION ENG110382-ENG20518 SCR inducem system status-incorrect reagent INCORR_REAG ENG110382-ENG20518 SCR inducem system status-incorrect reagent INCORR_REAG ENG110382-ENG20518 SCR inducem system status-incorrect reagent INCORR_REAG ENG110382-ENG20516 SCR inducem system status-inducement system active active
Just remains the mystery what's the root cause -
They are in the blockmap -files you posted. I compared your files with quite a few of my logs - on yours they are different than in my logs (no faults) that''s why I believe they are some kind of status "flags".Where did you find the engine flags above mate
heres the live data log hope I've done it rightThey are in the blockmap -files you posted. I compared your files with quite a few of my logs - on yours they are different than in my logs (no faults) that''s why I believe they are some kind of status "flags".
Thanks! Intriguing data
A few snippets below -
(A) NOx sensor is powered at 672.56 seconds (12 minutes) - normal
(B) NOx sensor "initializes" approx. 20 seconds later (pattern 1650,...) - normal - starts reporting meaningful values a few seconds later - normal (below green 28, 46, 57,...)
(C) OBD channel IDE04098 for NOx sensor "wakes up" a minute later at 759.67 seconds - normal'ish
I do not have exact data on this - just observed that indeed there is a delay 1-2 minutes between sensor raw data and the OBD data (NOx11...)
I apologize unclear instructions - should have mentioned it's best to search the channels by IDExxxxx numbers as the descriptions are not always unique. A few channels of second NOx sensor (which this engine doesn't have) were now recorded - thus just no data from those.
However, the NOx values (channel IDE09017) show NOx average of 78 ppm - which is quite/very high when compared with engine revs on journey (average 1290 RPM).
I would expect to see less than 25ppm under these condition (even below 10ppm with the updated ECU software). The above might actually explain the P20EE faults in earlier log.
I believe the NOx sensor works correctly (wake up, live data). Assuming the values reported by sensor are of right magnitude, the evidence (high NOx) suggests that the AdBlue injection might be seriously hindered.
Do you know if something was done with the DPF approx. 10000 miles ago?
After speaking to previous owner he said it had a dpf clean by a proper company a year or two agoThanks! Intriguing data
Hmmm... that's interesting - makes me wonder why. The DPF should last over 150.000 miles.After speaking to previous owner he said it had a dpf clean by a proper company a year or two ago
Did the Basic Setting (above) do anything?Sure, probably the one you are looking for is: VCDS > Select Control Module > Engine > Basic Settings > IDE10240-Resetting reduction agent fill level detection to sensor value
Have you tried Adaptation of EGR... under Engine - Basic Settings?not sure why im still getting egr faults as its been changed
Yes, by comparing first and last blockmap - sensor reading went from 131 mm down to 119 mm - while driven 691 km.Is the Blockmap showing the adblue level dropping?
I guess blockmap data was not captured right after the reflash? Would have been interesting to see what was different.Bit of an update to the saga garage has done an scr reset forced regen and reflashed ECU EML has come back on with p20ee code and egr insufficient flow within 60 miles but no adblue countdown as yet
ENG110382-ENG20519 | SCR inducem system status-deviation of reagent consumption | CONSUMP_DEVIATION |
ENG110382-ENG20518 | SCR inducem system status-incorrect reagent | INCORR_REAG |
ENG110382-ENG20516 | SCR inducem system status-inducement system active | active |
I believe they are related. P20EE just indicates too high NOx level in the exhaust, which is a consequence of poorly working NOx reduction system as a whole. Thus a guess would be either the AdBlue system itself - P204F, or go with P20EE NOx Catalyst Bank - Efficiency too low. In the worst case the latter would mean that the SCR trap catalytic converter inside the DPF isn't working as desired.Just short of 200 miles and the adblue warning is back any ideas what i should try next pretty sure its the p20 ee fault thats put the warning on
@mmi your advice to 'reset reduction agent fill level detection to sensor values'.Did the Basic Setting (above) do anything?
I have the countdown of doom with no suggested refill amount.
Will it do any harm me following this step and seeing if it clears the countdown?
@mmi
Reducing agent sensor fill level actual value = 4.291in
Remaining vehicle distance= 5166.94 miles
Dashboard Urea operating range - 215.61 miles
MFD displays 500 mile range (no advice on fill quantity)
