Cheers, You can tell I’m new to this forum malarkey
Fantastic, thanks so much @Pauly. Can’t tell you how long I’ve been trying to identify those!Yes that’s a standard connector, yours will look the same/very similar
The connectors are available online, search ebay for vw crimps or JPT crimps (junior power timer) and should find what your after
They look perfect, thanks @murphyabu.I did the same a few weeks ago, used these, worked a treat!
I need to find someone in Cambs/Beds with VCDS to code the speakers, Carista doesn't do it
Is this diagram the back of the radio or the plug, if plug which side the connection side or the back? Thanks
It’s the back of the head unit as you’re looking at itIs this diagram the back of the radio or the plug, if plug which side the connection side or the back? Thanks
Hiya is this the basic obd11 or advancedJust done my first coding with ODBEleven. Control unit 5F Multimedia. Byte 4. Set bits 1 and 7 to one. Equivalently, change the hex value from 3C to BE. Slide to write. Turn ignition off and on again. Fader now active!
Hopefully this is useful for ODBELeven users without the drop down boxes in VCDS, especially since they have a sale on at the moment.
I have the subscription that allows me to do codingHiya is this the basic obd11 or advanced
Just done and thanks to your instructions it was a success, thanksJust done my first coding with ODBEleven. Control unit 5F Multimedia. Byte 4. Set bits 1 and 7 to one. Equivalently, change the hex value from 3C to BE. Slide to write. Turn ignition off and on again. Fader now active!
Just tried to enable fade using OBD11 and it's failed because my rear outputs are wired to my active sub so it's obvisouly not seeing any speaker impedance so the question is this:
If I temporarily wire in "real" rear speakers, activate the fader, then remove the speakers and re-attach the active sub will the fade option disappear when I restart the van or radio?
Yes more than likely as the headunit does not see a load when using a amp, this can be got over by wiring in a load device to simulate speakersJust tried to enable fade using OBD11 and it's failed because my rear outputs are wired to my active sub so it's obvisouly not seeing any speaker impedance so the question is this:
Well by the 'eck. Prior to installing the helix dsp I did have a Audisson USS4 fitted to eliminate amplifier bump when the HU powered off but removed it because the helix can switch off the amp before the canbus powers down the HU so no more bump. I guess the USS4 is now going back in on the rear outputs to act as speaker simulator.Yes more than likely as the headunit does not see a load when using a amp, this can be got over by wiring in a load device to simulate speakers
I doubt it would check impendance while coding, probably fails due to something else.
I have all speakers ”Not installed” as all four channels go directly to amp and still got a fader. Having them ”Not installed” disables impedance checks so I also don’t have speaker errors on 5F.
Have you tried different views - on top menu line, 01010110 etc.
Android version has a drop down box...
Do you have a link or part code for these pins please?You need these pins
To go into this block
And you need to slide out the purple pin in picture as this is what locks the pins in place after u have clicked them in
Just done my 1st also. Thanks for the info. On 1st attempt it left my radio permanently on, so done a re-rack and worked perfectly. Well happy.Just done my first coding with ODBEleven. Control unit 5F Multimedia. Byte 4. Set bits 1 and 7 to one. Equivalently, change the hex value from 3C to BE. Slide to write. Turn ignition off and on again. Fader now active!
