Aftermarket Digital Instrument Cluster
How have you done that mate? I can't connect my phone
Select the nav on the dash and follow the instructions on the left hand side. Connect to the dash WiFi, use password 12345678 then open yours maps app. Go to mirror screen option and select mirror. Turn your mobile sideways and the map on the dash follows suit.
Yes I think that’s what it will be as I did disconnect the battery, thanks @Pauly
In case others dont know, after battery disconnect. Hold up, windows all the way up until stop, release, hold up for 3 seconds. Repeat to full low position, release, hold down for 3 seconds. Gives the vehicle limit stops for windows, steering each way full lock to make any lane assist or possible radar re center itself (not necessary for most).
Digidash with no MFSW Update:
We can get a remote control module factory coded to your digidash so you can operate without the need for MFSW mods. These will of course still work in future if you get them. But it means you can setup and calibrate everything on the dash, and then get it how you want it and leave the remote in the glovebox. Hurrah..
Adding products variants to the site now..
I just thought that it might be useful for you to know that your site appears to some security systems insecure. I was trying to view your web site and receive warnings that it is not secure. I realise that I could overcome this, but I chose not to do so, however for business in the long run it may be preferable to change things for the long term because it may well put others off also. Good luck with your enterprise.:)
Thanks I will check that out. It's likely something in the shopify settings. I assure you it is secure and there is only me at the other end logging in and out using 2FA :)
So my digital dash is working well, one small issue I have is that I get a ding sound from the dash when my Speedo hits 45mph, any shed some light.
Helpful comments only lol
Anyone used cruise control and had a difference in the requested speed and the actual speed of the van.
Set cruise at 75mph yet speedo showed 70mph. Same on google maps.
Is there anything to adjust?
Same here mate
Same here mate
Try your setting calibration speed on +5 in the calibration menu - below the fuel ltr number, then try again. At the same time check your driving speed on a gps app, waze will do.
I would want to be making sure the gps speed and the speedo are very close. Cruise is setting the OEM board, the virtual is just trying to read it remember. I wouldn't be happy aligning the gps and actual much under 60mph to minimise margin for error.
Being CCS mine doesn’t show a target speed so I haven’t noticed anything astray.
A thought. I've manly and butch 18" swamper wheels on mine and the speedo under reads a touch as a result. Can the settings in these beasties be tweaked to correct this sort of thing? Not an issue if it can't.
