That's the thing probably No access to it at all and always run you AC on fresh air you have a pollen filter filtering the air. Brief recirc to bring temp down quick but put fresh air on and shut down the A/C before turning off engine. The coil could frost up slightly with no fans running with the pressures equalizing in the system just adds more water in the drip tray then your van sits there weeks.... but you see the pattern every time you shut down and walk away
the A/C comes on with heating your screen.... its to help Dehumidify the air its blowing warm air over the chilled coil making condensation that runs out the van there's a cartridge you set off in the van for cleaning the coil
autoglym looks ok
Autoglym Air-Con Cleaner: Amazon.co.uk: Car & Motorbike
