Alarm contacts
I'll leave you to pick the bones out of that o_O
Well, I had a thought how possibly turn off alarm on trailer disconnect - thus your scan was very welcome - thanks again!
I had noticed there is coding difference between vans with factory installed towbar and vans without (or fitted with aftermarket one). Also a glimmer of hope was that the differing bits were not documented in VCDS nor in other tools.​
The suspect coding: BCM byte 1: bit 2 and bit 6 were "11" without OEM towbar. With factory installed OEM towbar "00".
My van has a factory installed towbar and alarm - thus perfect testbed to try to disable OEM trailer alarm by tweaking those bits (to be the same as on yours).
Here's what I did:
(1) Read BCM "blockmap" data, which contains​
a) vans convenience system configuration: e.g. tailgate internal opening switch installed, function activated,...​
b) switch, sensor, actuator, light, etc., statuses: e.g. window switch off, down, auto-down, etc.​
Basically the data forms a matrix of 233 by 4.​
Below a snippet how the decoded (by VCDS) matrix looks like.​
(2) Changed the coding from "00" to "11"​
(3) Read the blockmap data again​
(4) Compared the blockmaps before and after to see if anything was changed by the coding - I was hoping to see e.g. an (undocumented) "installed" to be changed now to "not installed". Unfortunately, no change anywhere was detected - thus not was not expecting much further.​
(5) Anyways, verified also on the van itself: plugged in the trailer, verified trailer was detected, lights were working, etc.​
(6) Locked the van, waited 60 seconds, disconnected the trailer plug - alarm sounded. Thus no luck disabling OEM alarm for the trailer.​
Conclusions?:
The (undocumented) coding difference between yours and mine doesn't disable trailer alarm. Actually couldn't spot the effect of the coding change. So remains a mystery why the codings are different from factory.​
The tests above suggests that the trailer controller installed on yours doesn't have trailer alarm functionality.​
Well, UNLESS someone can confirm the trailer alarm actually works also with aftermarket towbar controller - @Robert @Lukavell @JasonW @Van Buddy @rod_vw ?? ;)
Just another observation:
All the scans I have with the same aftermarket trailer controller have exactly the same coding - no help there either...​
