Amp off leisure battery
snoop6060
This is probably a very daft question but I’ve had a long day fitting a new lithium battery and related gubbins. I did have an amp attached to my starter battery, but I didn’t think it would fit under the seat with the rest of the stuff so I reused the supply cable for my dc/dc charger and was gonna remove the amp. But not decided I don’t want to as it’s too much work…
Can I just power this from the busbar that’s attached to my new lithium battery? It’ll only be on when the vans moving so guess it’s gonna be powered by the dc/dc charger as that will be active when I’m driving… but is that gonna mess something up as I assume it draws quite a few amps.
Probably a simple question but I’m frazzled .
No problem, just make sure the cables are fused correctly.
Ooi... What lithium? Dc-dc? What size or power amp?
Roamer 230ah seatbase and that Renogy 50amp small one you recommended. It’s all in and fused correctly, looks neat too. Been a mission getting it all sorted from my previous install but should be back on the road in the morning :) friggin expensive!
