1, the 2 black stripes are the remains of the vinyl wrap that was put on the cover the footprint of the original flexible panel that failed. So purely cosmetic.
2, the extra layer that you can see is where I cleaned off the glue from said original panel, the new rigid panel covered it up. Again, cosmetic.
3, the aero brackets sit just inside the raised lip, not on it. The panel sits in the brackets & there is an air gap between the panel & the roof created by the brackets.
4 I reused the original cable that was fitted by Reimo. I put MC4 connectors on the end to connect to the panel. The connections are under the panel & cable tied up out of the way. The cable passes through the roof on the outside of the canvas & passes through the canvas in the OSR corner of the roof.
5, the mounts are bonded to the roof with “sticks like sh*t” which it does. The rear bracket actually sat over the cable exit hole, so I drilled a hole in the bracket foot to match up with the existing hole in the roof to pass the cable through.
6, Panel is 150W
