Good idea with the plunger, I’ll remember that. Your right about ladies and long hair ‘kin nightmare, even had a clogged dishwasher pump!?
Pubic hair is also the work of the Devil.
Have you tried the Karcher drain cleaning attachment - I've not used mine in the house but have used it to quickly clear a couple of blockages outside between interconnecting manholes, etc. - not overly expensive but you are welcome to borrow mine and give it a go. GENUINE KARCHER 7.5m Drain Pipe Cleaning Set (2637729 2.637-729.0) | eBay
Did this every get solved, @Tourershine??
Sorry chaps.
No, we had a preliminary inspection, but it's more involved than a bottle of Coke.
Next step is kitchen cupboard out to cut a hole in the boxing in panel to assess the stack.
Sorry chaps.
Side bet its wet wipes
Yep it will be vaccum. Depending on if it's a single or double bowl sink you could either just swap out the trap as already mentioned or fit an additional 40mm air admittence valve in the pipework if space.More than likely need an air admittance valve. The trap water is probably being sucked out by the vacuum causing smells from the drains to enter the property.
It would need to be 1-1/2" to fit the kitchen sink pipework.Swap the current trap out for one with a valve built in, such as this one;
Other valved traps are available..
