Audi RS4 Seat Upgrade
Hi @Superchargedgti what did you do exactly to get the movement and especially the heating working ..
Hi the power for movement in the seats I’ve used the passenger seat fuse box for additional separate supplies to each seat with 25A fuses
Still waiting for a kufatec loom for the heating but I have the new dash controls,seat heat control module and Audi seat plugs for the new loom
Will post on here when it’s done 👍
Hi @Superchargedgti where are you getting the Audi seat plugs from?
Thanks @Superchargedgti .
As my install turned into a bit of a wiring massacre, when you can I’d appreciate knowing just the specific parts you’re working with and have bought to make it all work - -
First off, a QQ: what was the original Audi seat control unit/module that came with the seats?
Moving on to your shopping list..
What is the new seat movement controls youve got?
What dash heating controls and module have you bought?
What is the kufatec loom for the heating you’re waiting for?
If you’re doing a T6.1 and want the heated seats as OEM as possible (and controllable more than just full blast on or off), then you need the climate Panel with the heated seat buttons and also the seat module. I managed to get them off eBay for about 120 quid for both, which I think was a bit of a bargain as i have seen the panel go for 2-3x that on its own. It also needs coding, but I havent got that far yet as still trying to work out the loom. I have the part numbers for the above if you want them LMK and I can dig them out.
