Thats great thank you. Nobody lives near meThis is what I have under my passenger seat power from the relay is split into two wires one for each seat with separate fuses .View attachment 276408View attachment 276409
Hi thank you Stan that’s good idea to try switch them over but I wonder if are both dead lol I need check module number and see how much goes for it might be enough cheap to replace and then see if will work, one seat wire looks ok but other I was trying to but back and could not find all ends to connect……. Might need replace full wire. Just did image of module and I can see 2 thick wire goes to module might try to connect to them instead.These seats are getting more and more complicated. You could try swapping the modules under the seats to see if that’s the issue as they do the controls of the seats. Older ones are wired directly to side switch with nice and thick wires where them now are all skinny bastards though said modules .
Also these modules are easily locked when people try to fiddle with wires. So that could be the issue with one of them possible as well. Someone before you could have tried to wire them hardcore style as you can see from the chaos caused there. You’ll know once you might be able to swap the modules around and check.
I wouldn’t advise to try to start changing polarities on them as it’s still module that switch cooperated with not direct voltage.
That are super sexy tho
Snakelimit, your seat dont work because you have a memory electrical seat, the passenger are not memory (just 2 cable for make thi run)
I see will need to check it when van back from garage unfortunately passenger seat a bit in pieces with wires and I might just connect motors to switches and use that way.Snakelimit, your seat dont work because you have a memory electrical seat, the passenger are not memory (just 2 cable for make thi run)
But for the driver seat with memory, movement make by a unit control under the seat. Just add the + and - are not correct
you must add the Can connection (6 and 7 on the black plug) actually i dont find a solution for that, normally can are low voltage under 12v...
they look great. I am looking into this sort of thing. where did you find the seats, what year car etc. it seems a better deal than have mine re trimmed. what sort of money are the seats, they look good. I am near Emsworth so would love to see how you fitted etc. PM if you don't want to post certain info. cheers NHi guys I’ve recently replaced my front seats with a pair of fully electric Audi A4 RS sports seats. Had to modify the own seat based as the Audi seats are wider I’ve got the movement functions working which involved running a new constant power feed and an ignition feed to a relay. My original seats were heated but I can’t work out the connections for the Audi seats yet . The originals had 3 connections and the Audi seats have 4 wires if anyone has done this modification could you let me know if you got the heaters working.
Original leather captains seats listed here.
View attachment 265324View attachment 265325View attachment 265326View attachment 265327View attachment 265328
Look at ebay there plenty of seats from vw/audi you will need adapters to fit thenthey look great. I am looking into this sort of thing. where did you find the seats, what year car etc. it seems a better deal than have mine re trimmed. what sort of money are the seats, they look good. I am near Emsworth so would love to see how you fitted etc. PM if you don't want to post certain info. cheers N
