Bad VW franchise garage !!!!!!
6.1dom
This is gonna be a long one so buckle yourself in.
I’m new to the transporter lifestyle. I’ve always wanted one and I managed to buy myself a 6.1, T 32, CXEC biTDI, LWB, DSG, LEDs used for £26k last month from a VW franchise in the UK. I have been looking for a long time for a Van and when this one came up, I thought it’s perfect. It has done 60,000 miles but that doesn’t phase me as it’s come from a VW garage with warranty. When I bought the van, I took out the maximum amount of extended warranty and when three years is up I will extend it for another three years as I’m self-employed and I need my van for my job.
To tell you a bit about myself, I used to work for VW as a diagnostic technician on passenger vehicle around 6 years ago so I know how VW operate and what the used multi point check consists of.
When I was in the sales office, I mentioned that I worked for VW and I also mentioned that I have a friend that is a technical trainer for VW and that he did a in-depth background check on my van and will be checking all the work that been carried out on it. Hoping that they would do the right job the first time and that they can’t pull the wool over my eyes, as I know what they’re like.
The van was delivered to me and I did my own inspection of the van on the floor as I don’t have access to a ramp. I found that the front nearside shock absorber was covered in oil that the rear centre brake light was broken and a host of other issues. They agreed to pick up the van and leave me a courtesy vehicle. They fixed the issues and said they’ll do a thorough check on the vehicle again as they might have missed things on the first multi point check they did. But reported no other issues found.
Then, when receiving the van back I’ve started to notice that the Dual mass flywheel is knocking badly and that the DSG gear box isn’t smooth when changing gears. They’re going to change the flywheel first then road test and see if that clears up the DSG issue. If not then new DSG box.
So now the van is back in the VW garage for the 3rd round. This time it’s got the master Tech checking the vehicle over and he has found another huge list of smaller errors including when they changed the shock absorbers they left off the bump stops off and dust seals.
It’s hard as a technician you get trained to manufacturer specification and then your franchise wants you to hit these stupid targets otherwise you and they won’t earn any money.
I used to do this as a job so I have no problem finding issues with the van, the reason I left is I couldn’t cut corners. I had to do a proper job but the franchise deemed me not efficient.
it annoys me that they operate like this as the majority of customers would have no idea.
You can have it right,
You can have it now,
But you can’t have it right now
Just shows that they probably never did the multi point check! At least you have the warranty. I hope you get it all sorted. Post some pics :)
Nothing new here,
I think we've all experienced the main dealer failings. Some worse than others.
At least they have taken the van back in and accepting liability for the repairs.
Many on here have been fobbed off and had to pay.
Keep us posted on your progress.
I will definitely keep this thread up-to-date. The flywheel will take a week, but if it needs a DSG gearbox, then this can take weeks to come into stock, apparently.
When I worked for VW, we used to strip the gearbox down to fix issues but now they just replaced the whole box which is good under warranty but not so good for people that are buying it out of warranty.
Nothing new here,
No one needs to pay for anything now. I’m on this forum if I see threads like this coming up, I’ll be trying to help out.
We don’t have trained mechanics or technicians any more….we have box-openers now!
Maybe that’s why I didn’t fit into franchise garages I like raw mechanics not just plug it in and replace the part. You need to find the root cause of the problem.
But it can also be the other way round,
i drove my 65k highline T6 out of a vw franchise 2 years ago next month, before it was done it had had new clutch, flywheel, discs, pads, cambelt, water pump, full service, with FSH
I got 15 miles down the road and the EML came on, turned around and back, EGR fault, they then went onto clean EGR, replace both pipes and 2.5 hrs later a lot of coffee I was off again no issues since.
My only complaint is the persistent calls and emails about servicing as I've told them umpteen times i live a 2.5 hrs drive from the garage!!!! one of my besties is a 25 year Vw master mechanic, I've unsubscribed and called to ask to be removed!!! and they still persist!
My only complaint is the persistent calls and emails about servicing as I've told them umpteen times i live a 2.5 hrs drive from the garage!!!! and unsubscribed and called to ask to be removed!!! and they still persist!
I totally agree not all garages. I like it but when you’re spending good money to buy a premium van, you at least expect a premium service like you received.
We are waiting for a warranty approved replacement DSG box on our other van...
Been In The garage for 3mnths now.
DSG box has no eta from the factory (in Germany or somewhere?) .... Raised a complaint at customer services... Same answer... No eta......so we just have to wait.!
That is absolutely disgusting. You pay all this money for a premium van,and they can’t even make a simple gearbox.
I contacted VW customer service and they are useless. They flag the garage but that’s it.
So do you just have to wait? Is there nothing else that you can do?
When I bought my T-Cross, approved used, it came with just 7 months MOT, a known tailgate rattle issue, and 4 year old maps. No mats and free moss around the wing mirrors sir? Yes please !
They didn't want to know !
I gave the salesman 3/5 and then received constant emails from the sales manager to see if I could 'up' it.
Is that when you used some of the f*** off Spray?
VW moss, that’s the good stuff.
As I said before, they only interested in maximising profits and if that means doing no work on your vehicle to save money then they’ll try and get away with it but I’m not having it
Done everything we can.
The only silver lining is that the all-in warranty has covered the £5k cost and the garage has given us a new T6.1 loan van.
Still messed up our camping season though.
Se we just need to carry on with there van until the part is available?
We chase weekly both the garage and customer services.
What drive you to give 3/5…..were you feeling generous that day? Well, if he wants to improve his service, you could always consider improving your score!!!
I’ll try and do all your travelling in the loan van get the miles up on that thing at least you won’t be putting it on your own Van but I suppose they haven’t given you a camper as a loan vehicle just a standard panel Van?
Gradually over the years the human race has evolved and Engineers have now evolved into a higher form of life, to whit, Fitters. This is true across all forms of engineering, civil, mechanical etc. For years I took my cars and bikes to a proper time served, experienced Engineer. He held more patents for Morgan improvements and accessories than the Morgan Motor Company itself. Then, sad day, he closed down as he couldn't make the money he needed to feed his family. He is now an MOT tester at a local garage, it pays more and he has no overheads.
We live in a world where instant gratification is desired and expected - I want it now, not in 2 days time - replace it, don't repair it and chuck the old one in the bin.
/rant
/rant
Welcome to capitalisation
/rant
The other member on here has been waiting three months for a gearbox and I’ve been waiting over a month to get a basic service from VW. I’ve only asking for the basics of how they’re supposed to operate as a garage.
Give that a read may help you out
