EV's......the way forward
Low service costs and long intervals
But bought a diesel van ?Don’t tell everyone, but after VW, I ended up working at one of the big leading electric car manufacturers
If you could find me a long wheelbase EV that does 300 miles without a charge for 26k then I’ll buy it but more like be spending £60kBut bought a diesel van ?
In China?
I'm sure a 3 Yr old Buzz, lwb, 7/8 seater can be had for that in 2027If you could find me a long wheelbase EV that does 300 miles without a charge for 26k then I’ll buy it but more like be spending £60k
I would buy it for 26k too.If you could find me a long wheelbase EV that does 300 miles without a charge for 26k then I’ll buy it but more like be spending £60k
Based in USA
You know how we were talking about garages not doing the right thing anymore and just changing parts without doing diagnostics well the electric car manufacturer I worked for may surprise you that they actually do in-depth diagnostics. You can’t just change your part and hope for the best.
Exactly that’s why I’ll buy a diesel cause there’s no other options yetI would buy it for 26k too.
I don`t think there is an electric van, lwb, under 2m height, payload >1 ton with a 300 mile real world range.
Dealerships are useful for certain things when you know the law and you know how they work at the moment they’re doing exactly what they should’ve done in the beginning and they’re gonna fix everything. They should’ve found the first time if you just take your car or vans of them and expect them to get on with it on their own without you checking then you’re gonna get mugged off But I want my money’s worthWhen I read threads like this it makes me wonder why so many people on here are so keen on the "All in"
I avoid main dealers at all costs.
The VW 2 service plan works out just over double what I pay for the same service and parts at my independent using genuine parts and oil.Also if you book your service online with VW commercial then you pay the national fixed price, dealers often charge more if you book direct.![]()
Fixed Cost Maintenance for Vans | VW Vans
With Volkswagen you can pay monthly for servicing, maintenance and tyres if your vehicle is less than 12 months old and has covered less than 10,000 miles.www.volkswagen-vans.co.uk
The 2 service plan seemed the best value.
The service insider things is shit I admit that that’s why I go to independent and use genuine parts but when claiming on warranty the garage has to use all the parts as new even all the bolts are nuts otherwise they won’t get their payment from VW but most independent garages won’t use new nuts and boltsThe VW 2 service plan works out just over double what I pay for the same service and parts at my independent using genuine parts and oil.
My independent uses all new parts as specified in the manufactures maintenance schedule. Any service centre that doesn’t adhere to the correct maintenance procedure is taking a chance and future failures may resultThe service insider things is shit I admit that that’s why I go to independent and use genuine parts but when claiming on warranty the garage has to use all the parts as new even all the bolts are nuts otherwise they won’t get their payment from VW but most independent garages won’t use new nuts and bolts
I don’t know if you’ve read my original post the whole reason I started this thread was about the garage not following protocol and process and leaving stuff off when they’ve done a repair. That’s why they’re a bad garage.My independent uses all new parts as specified in the manufactures maintenance schedule. Any service centre that doesn’t adhere to the correct maintenance procedure is taking a chance and future failures may result
Sure did. I think we all agree that even in 2024 there are bad garages. It’s a problem that I’ve been aware of for over 40 years. A lot of people haven’t got a clue about vehicle maintenance and trust the garages to do a good job. Sadly some garages do get away with less than a perfect job. I like to see a documentary series on how big franchises compare with the independents and get them exposed for good and bad workmanshipI don’t know if you’ve read my original post the whole reason I started this thread was about the garage not following protocol and process and leaving stuff off when they’ve done a repair. That’s why they’re a bad garage.
If I was you, I’d buy a UV solvent base pen and Mark across the filter housing and the top line and then use a UV light once I’ve carried out the service because it will never line back up perfectly and you’ll be able to see if they’ve bothered changing the oil filter as some technician is in such a rush they don’t bother changing them.
If you wanna help your van last as long as possible I change the oil every 6000 miles and they stay VW should be done every two years so I’ll have the book stamp. I’ll use the filter still and a decent VW spec oil and I’ll be doing the service in between.
I looked at the service intervals for some of these filters. Can you’ve got to wonder if VW has got your best interest at heart? Fuel filter every 120k
Pollen filter every 70 K and the oil was something like 20,000 miles, which is ridiculous for oil
Regarding software updates, there’s not much to update, specially if you’re using your phone as the satnav. Tesla firmware updates get new features and a new interface like your phone updates. Tesla uses an Tesla uses a Linux based system. Most car manufacturers still use a more basic system in comparisonI’ll do that trick with the pen, I bought the van with 2 year service plan thrown in, the van has only done 3500 miles since last oil change, 18000 in all!!,
but light came on in van so got it booked in, when on the phone they mentioned software updates and said it was in plan, so I’m not expecting to pay anything. I always use my maté garage for my cars, when the plan is through I’ll probably go back to him, I change oil every year on my vehicles , my bike has 3500 miles and it’s had 4 oil changes already, most vehicles I use do 8-10,000 miles a year, but if it’s less at end of the year it’s getting changed!!!
Get it mapped outTalk to us about the T6 adblue software update.....the one that increased the consumption of adblue to stop the EML getting triggered. Was there an insiders take on it? @6.1dom
