Not from the bcm after clearing. But iam sure they will appear once more. The fault regarding it not being able to read the tailgate status.Any fault codes??
I am not sure how this would be possible or for me to check. As I mentioned I did goto the trouble of running the 2 wires all the way back to the bcm. I am pretty sure the switch in the tailgate the soft close switch is just shorted to ground in order to send the message to the bcm.Any chance the handle switch is somehow wired in series with tailgate door contact switch (006-2) because that would explain why BCM/VCDS does not see the handle switch operated (in 008-4) anymore when group 006 shows closed-closed.
I think the door closed (BCM 006-2,3) means that then the door contact switches themselves are actually open - as below
I mean any fault codes now after a couple of lock/unlocks, playing with tailgate handle at different tailgate positions, etc.Not from the bcm after clearing. But iam sure they will appear once more. The fault regarding it not being able to read the tailgate status.
Correct - that's why I'm thinking when the door contact switch opens (=door closed-closed) the BCM can't see the handle switch anymore.I am pretty sure the switch in the tailgate the soft close switch is just shorted to ground in order to send the message to the bcm.
So, the tailgate handle switch was obviously a new wire - connecting into BCM pin 23 (black connector).As I mentioned I did goto the trouble of running the 2 wires all the way back to the bcm. I am pretty sure the switch in the tailgate the soft close switch is just shorted to ground in order to send the message to the bcm.
Ok I will give this a go today and let you know how I get on. I understand what you’re saying. But if I just earth this wire that goes to the bcm. How am I going to use the tailgate switch ? In futureSo, the tailgate handle switch was obviously a new wire - connecting into BCM pin 23 (black connector).
Can you tap on that wire and simply short it to ground - and verify with VCDS measurement group 008-4 that BCM recognises it (the red box showing as "Active"), also in tailgate position closed-closed. If still not seen in 008-4 perhaps need cut the wire (to isolate tailgate wiring completely) and short to ground just the BCM end of the wire.
If still struggling please measure voltage (against chassis ground) on that wire in different tailgate positions - both handle switch not pressed and pressed.
Earthing the wire (close to BCM without tailgate wiring involved) is just to verify that the BCM registers it correctly as "Active" in 008-4 even when tailgate is in position closed-closed.Ok I will give this a go today and let you know how I get on. I understand what you’re saying. But if I just earth this wire that goes to the bcm. How am I going to use the tailgate switch ? In future
Ok so I did some further testing. I will try to describe what I did. I did also make a video to show the behaviour of the locks whilst carrying out the test.Earthing the wire (close to BCM without tailgate wiring involved) is just to verify that the BCM registers it correctly as "Active" in 008-4 even when tailgate is in position closed-closed.
The would prove there is a wiring issue inside/close tailgate. The earthing is not meant to be a permanent solution, only a measurement.
But this is a significant step forwardSo now closed closed status
Now this is where I now also get a reading which I don’t get when using the earth in the tailgate. Using the earth on near the sliding door. It now does register the button press of the handle and shows active when pressed or in this case when I earth the cable.
Another or the same wiring issue as above???Unfortunately what it still doesn’t do is power the actuator to open the tailgate.
Yes it seems that with earthing the tailgate switch it will register the button press even when closed closed status in the messing blocks. But that still doesn’t explain why it still won’t open the tailgate even when it knows the correct status ie closed closed.But this is a significant step forward- obviously need to get button to register also with earth in the tailgate. Missing earth or wiring issue?
Did you bring a dedicated wire through the bellows for tailgate earthing?
Just thinking that something dislodges at closed-closed because the solenoid definitely should pull then.Yes it seems that with earthing the tailgate switch it will register the button press even when closed closed status in the messing blocks. But that still doesn’t explain why it still won’t open the tailgate even when it knows the correct status ie closed closed.
No, not normal.Also I still have no idea why it keeps activating the central locking when the handle is pressed. Surely this isn’t normal?
