Is it the sockets turning off or is it the charger timing out.
I know on my CTEKs if the battery voltage/current doesn't behave as expected in the right time for the charging phase it times out and shuts down. It does put up an error light though.
Which charger are you using?
I am sure that this is a case of the socket not allowing the battery to charge.
When connected via either socket, the charger starts off normally and runs fine for an hour. The charger then ends up showing as being in absorption at 14.4v (viewed via Bluetooth) and yet the starter voltage just falls back to a resting voltage.
I have a Victron Blue Smart 25/12 charger and it charges the battery fine if connected to the battery properly. (IE-not via cigarette socket, but still in low mode at 10A)
See below screenshot from attempted charging via cigarette socket:
Start of charge at 1846 shows bulk charge, then as you'd expect the charge to reduces to float by about 1915.
All is well until about 2000 or so in and the charge just stops:
By contrast, using the same charger connected directly to battery, it can be seen that charger was started at 1910, briefly bulk charged, entered absorption and then float charge at around 2am, which is exactly what I'd expect:
Until charge was disconnected at 730 am.
So charger is charging exactly as expected, unless charged via a cigarette socket.
What is bothering me is I know for a fact that the cigarette socket is live as if I leave a usb charger plugged into it and observe the LED glowing for hours on end!
It is though there is some sort of diode installed to prevent charging from the sockets and this diode takes an hour or so to decide to kick in!
Maybe VW have designed it like this so that they can keep a van alive long enough for maintenance, but not long enough to allow continuous charge?
I remain a little confused over what is going on.
