Deep breath....Now be careful ....breath ....and dont break anything else!
Possibly, but Cu is still going to expand 50% more than the steel. Can tell by rubbing a file over a small area.Are they lead? I thought they were tinned copper.
Never leave tools on top of a battery (your first photo). My neighbour is looking at his burnt out BMW every morning after making that mistake.Deep breath....
Exactly that...came out...I reckon that bolt is probable replaceable, whats on the other side of the broken bit? (Underside of the clamp) can't see it being cast as part of the clamp so its maybe just pressed into a hex on the other side ....?
Bingo, just been looking for this... You think this is the one? Will order it.. Thanks.M 8-1.25 x 35 Rib Neck Strut Press In Stud CL 10.9 Zinc
M 8-1.25 x 35 Rib Neck Strut Press In Stud CL 10.9 Zincwww.clipsandfasteners.com
In my cart at the moment... Seeing if there is anything else... ThanksAmazon do a pack of 4 but they are only 28mm long, is that enough to go through the battery terminal and leave enough to bolt the cables onto?
28mm is probably original size too.. Trying to get the snapped bolt out of the nut. Nut being permanently on the wire, as I have found out..In my cart at the moment... Seeing if there is anything else... Thanks
Yes, I drilled the nut off the Pos wire, as it is attached.Did you get this sorted ?
