i need to add a wire into my BCM for my tailgate conversion. What’s the pin part number or where can I get some?
I thought it was closed. @PaulyForum shop might have a few to sell now mate..
It has but he may have a few kicking about in the clear upI thought it was closed. @Pauly
It is from my experience working on BCMThanks Robert, I have those pins but position 63 is much larger. It must be 6.3mm wide and its for a 2.5mm2 wire. Where did you find those part numbers? Is there a look up diagram somewhere.
I can’t see why not this is the two repair wires I had for mine as long as the pins are the same I can’t see a problem you may want to I’d them with some sort of label or ferrule
