Skoda rapid pq25 2013
BCM t6 7E0937090+auto light switch(still no installed ), just waiting for all pin and wire in the moment .
Any way bixenon headlight already on board and working , only led drl no working in some scenario and i canе blinking high beam if the light switch is in the zero position, i know i just need to harness cople of wire from headlight to fresh bcm but why not to order complete set like to free yourself from work outside the car Polo 6R LED Bi-xenon adapterkabel - NB Car Performance
I would just like to be sure if this will fit the Skoda .
as in terms of diagrams and connections to the headlights on all these cars they are identical?
OEM 5JB941015C Xenon Headlight Skoda Rapid facelift with DRL
10 Pin Audi/Seat/Skoda/VW Halogen Headlight Connector Plug 6R0973735 / 1J0973735 from H Bowers who specialise in the sale and supply of automotive components. Order online with next day delivery available in the UK.
For halogen headlights only, not suitable for Xenon.
Not suitable a
Bixenon work well+led drl!
it seems to me that this plugin has not changed even after these years that are declared
In addition to replacing the BCM, what needs to be done for the normal operation of the headlights? I mean now that they work fine anyway with new bcm, but the strip drl does not work with low beam ,
if i add a wire from the outputs of the drl to bcm ,that can help?without additional wires to lightswitch
3 Faults Found:
00886 - Turn Signal Switch (E2)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 195436 km
Time Indication: 0
Date: 2017.10.08
Time: 11:06:59
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 195436 km
Time Indication: 0
Date: 2017.10.08
Time: 11:06:59
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 195436 km
Time Indication: 0
Date: 2017.10.08
Time: 11:06:59
