Hi oliWe stock Revo 380mm brakes and very shortly will have some other brakes to offer too.
An you pm me a price for supply on these please
I’m actually out of the country at the minute. If you DM you contact details I’ll get someone from the office to get in touch with some prices.Hi oli
Oh shizz they are fresh!!!
Wow! What wheels are they please, Luca? Did you have to use spacers for clearance?
Thanks. Very cool!AUDI Q7 4L0 5x130 9x21 ET60
spacers 25 mm - change pitch bolt
Watching with interest....Anyone how have any tips of where i can get brackets in stock for Brembo 4-pot to OEM 340 disc? Dont need any brake lines etc. so 290 at VBT is a little pricey :s
Hi @CRS Performance, please explain how this is possible - "can grip the disc harder without locking up".Bigger brakes do control heat better and can grip the disc harder without locking up. These are benefits and although it’s an expensive upgrade worth doing .
If the standard brakes can supply enough torque to overcome the friction between the tyre and the road then surely that is the maximum force the brakes can without ABS kicking in (or wheels locking). Without increasing the friction between tyre and road (ie to stop it slipping/skidding) and the ABS kicking in then as soon as that same maximum torque is reached then the wheel will skid and ABS kick.
Lets make up some numbers to try to make my point. Lets suppose the OEM brakes overcome the friction of the tyres at say 100Nm of torque. Then surely as soon as the larger disks and callipers reached the limit of 100Nm then the tyre would start to skid. All other things being equal.
I understand that to apply this limiting force of 1000Nm the larger callipers would have to apply a smaller force as the radius of the disk is larger.
I also get the benefits (of the right set up) can improve feel. But also mis-matching the slave pistons in the callipers to the master cylinder can adversely affect pedal travel and hence brake feel (this is the reason the TAR.OX big brake kit was delayed).
Maybe @Nutexa Frictions might have some input into this?
What calipers are those, they look the part!!!!!!Half agree and half disagree here , apart from heat control we run bigger diameter discs to be able to grip the disc harder with out locking it up .
I do understand we are actually talking about Transporters and not track cars but Our track car ran full race brakes and we have to replace wheel bearings almost as often as pads due to the increased forces from a bigger calliper and Disc . The bearings suffer from the heat as well because of the increased forces from the brakes and slick tyres .
So I run 405 mm discs on my T 28 and apart from the obvious look they are unbelievable at stopping the van . ABS rarely kicks in unless the road surface is slippy
The Veemann wheels need race valves to work otherwise the valve hits the calliper
