Sold Bonanza - Victron, Renogy, Fogstar, Helix, PV Logic, Blink, TP-Link - Solar Leisure Audio Wi-Fi CCTV
t6blo
Ex-owner
T6 Legend
My van has too much bloat - I’m going back to basics, reducing weight and unused, unnecessary things. A sale bonanza.
Open to sensible offers and can post to UK (maybe not the Fogstar, need to check and not the solar panel) or you can collect, or I can meet locally.
I will add photos once I have carefully removed each item.
Fogstar Drift 105ah Lithium battery with Bluetooth and heater built in.
Bought in December 2023 and working perfectly. Ready to install under seat.
Includes original box and packaging
£275 (might be plus P&P if it is expensive)
Renogy DCCS50A DC-DC with MPPT includes the BT module which was an extra
Bought in December 2023 and working perfectly. Ready to install - will fit under seat with battery.
£150 inc P&P
Victron Smartsolar 75/15 MPPT with Bluetooth built in
Bought in January 2024 and working perfectly.
£45 inc P&P
PV Logic 155W Mono High Density Rigid Solar Panel
Bought early last year and working perfectly
No original packaging comes with a cheap PWM controller or use with the Victron above
£175 collection only
<photo to follow once removed from van>
Helix DSP Mini Mk2 6 channel sound processor
Bought last year and working perfectly - has a scratch on the top but only cosmetic
£200 inc P&P
TP-Link 4G LTE Travel Mobile Mi-Fi Hotspot
Just over a year old and working perfectly. Includes an EE 120Gb data sim with about 80Gb of the data remaining. Lasts until May 2024, then you throw it away and buy another one.
Powered by USB socket in the van and has internal battery too
£55 inc P&P
TP-Link Tapo CCTV C110 2K/3MP camera with night vision
I have 2x of these
Both have original packaging.
1x is like new with mains adapter.
1x has a 12-9v converter and the plug from the mains adapter and will need soldering/connecting up
They can be used in the van, in the home, baby or pet monitor etc
£15 each or £25 for the two inc P&P
There might be some more items which I will add later.
Some amazing bargains.. holy smokes... I could have saved hundreds of pounds
Hi. I’m looking to upgrade my power system.
I’d be looking to swap out my LB with a lithium so would be interested in a few things of yours for sale. But TBH I don’t really know what I’m doing or exactly what to buy.
To upgrade to lithium I think I need the DC-DC
And the MPPT for my solar panel. I’ve got one of the really thin flat panels the now that I will upgrade later.
I’m keeping my Sargent for the 12v but would need to change the EHU.
If you could help advise me on what I need and need to do I’d happily buy some of your bits for sale if they were what I’m needing.
@The Flying Scotsman the lithium battery will give you better capacity as you can use the full amount of the battery compared to AGM/lead acid. The Renogy is required to charge it from the van battery/alternator. Both the battery and the dc-dc have Bluetooth and smartphone apps so you can see what they are doing/monitor state of charge etc.
Depending on your solar panel, the Renogy also acts as a MPPT to charge the battery from the sun.
You would need the Victron MPPT if your solar panel is not compatible with the Renogy built in MPPT.
The Victron also has Bluetooth and an app to monitor the incoming charge from the sun.
Just the solar panel left - which I have still got to remove.
Will start a new thread for that.
Thanks all
Reactions: Bav
