Any help on what I should be checking, tomorrow I will check coolant levels after that I’m a bit lost!....thanks for any help
I take it you’ve tried with the direction switch in different positions?
Yeah tried every dial in every combination of position...still the sameI take it you’ve tried with the direction switch in different positions?
Morningdo the dials appear to be working?
ie direction and blower speed?
is its just the temp dial that has no cause/effect?
what about the AC?
does the coolant temp sit at 90C when the engine running? (dash clocks)
Hi
Dashboard Heater blowing luke warm
my dashboard heater started blowing luke warm yesterday, i took the trim off and pulled the unit out as far as it could. The plastic gear for the hot and cold dial has broken somehow. Does anyone know if i can buy this part separately and if so , whats the easiest way to replace it please ? @Paulywww.t6forum.com
The above is some information i posted when my heater started to blow cold. It may be helpful to you
Hi Andy thanks for reply, will look into it, cheersHi
is it something you could or be prepared look at as I see you’re a mechanic?Resistor pack only does fan speed, hows the van on the coolant temp do you notice it falling when driving sounds like you could have a stuck open thermostat or even water pump partially stuck if you have the electric style pump
Hi Forrest 4799 I have the same problem, what was wrong with yours please?Morning
ok I’ve been for a drive (25min) tried the speed dial works fine on all 4 setting, the directional dial works fine, the temp. dial is blowing only cold.
Tried the AC and just blows really cold.
Oil temp. Is as per photo which was taken after 25 min drive and the time it’s taken to write this reply.
looks as though it could be the temp dial not working, is it an easy fix?
what are your thoughts
again thanks for any advice
