Well I flagged it 4 months ago to Vw as under extended warranty but it’s got worse. They told me to buy an engine under tray to dampen the soundSounds like my washing machine with a spanner in it, who’s saying it’s good?
Did you get that in writing? If so send it to Customer Services and get their arse dragged through a bush.Well I flagged it 4 months ago to Vw as under extended warranty but it’s got worse. They told me to buy an engine under tray to dampen the sound
I did! I said to them if you think that’s ok then put it in writing. It wasn’t as noisy back in April/may time. I’m expecting a massive fob off again if I’m honest. I called road side assist out and he noted it down as being noisy also.Did you get that in writing? If so send it to Customer Services and get their arse dragged through a bush.
They definitely have it all on file. But they are crafty and don’t give customers work history out. I will ask for it tho before hand. The flywheel is definitely on their system.Have you got paperwork for that work 20k ago?
Did you call VW to get a work history report from them.
On my second one the warranty office needed evidence.... Which ment dsg box out to inspect the DMF.
I think they are all the same now. It’s a well known issue and they are all trying to fob the customers off with extended warranties and most likely only helping the ones in original warranty.Try a different van centre. My flywheel had a slight rattle which disappeared when the clutch was depressed and West Yorks Van Centre never mentioned any potential cost to me or any other financial jeopardy, I just dropped it off and they rang me and said they were putting a new dmf in under warranty and would need the van for an extra day.
That was a couple of years ago, so maybe the VW mothership has tightened the purse strings, but you can go to any VWVC. I bought mine from Liverpool but all my other dealings have been with Cleckheaton.
That sounds like my T6 4motion DSG it has 118k on the clock now but did not think it sounded like the flywheel,but listening to this it does.
Glad you got it sorted. Mine is starting to sound similar. How much did the flywheel replacement cost you?
Why was it rejected by warranty?
