Can I leave my Kombi floor in place when fitting units?
dss123
Hey...
I'm looking to fit some interior units into my T6 Kombi. Not a full interior.. just some side benches that fold into a bed.
I'd like a "non-permanent" fit using the lashing points.
Question is... is it acceptable to place such units straight onto the rubber floor? My fear is that it is quite "squishy" and might not provide a solid base. and the units might cut into the floor over time.
I'd rather not remove the rubber floor and do the whole batten / ply lining thing. Been down that rode with my T5 and would rather not repeat the exercise.
Or can one put a ply floor on TOP of the rubber floor... something with cut-outs for the Kombi Seat and lashing points?
Dunc
Hey...
Dunc
I have van furniture's kombi units that pull out to make a bed in my van installed on top of the mat, no issue with them cutting into the mat or that squishy feel, they are very stable. If i need to use the van as a van I can whip them out no problem
Some carpet underneath, a couple of strips layered? should absorb any vibrations/shocks?
Thanks Jim.... Good to know that it's worked for you.
You can definitely do this! Because that is what I have!
Well there are cut outs for the seat fixings and the lashing point are replaced and bolt through the ply.
The advantage of keeping the rubber underneath is that is provides an excellent custom moulded insulating layer.
Mine is from The Ply Guys and they fit loads like this.
You can see their 'Urlar' van ply flooring and pics here: https://www.theplyguys.co.uk/product-page/urlar-van-floor-system
Ah - this looks the business!
Thanks very much. Just what I'm after I think :)
The only fly in the ointment is they are collection only...... and they're in Scotland!
Ah indeed… they’re only about 10 mins away from me :-)
If it’s really what you want then just plan ahead and make the trip up (and combine it with eg a camping holiday)…?
Ah indeed… they’re only about 10 mins away from me :)
Another trip to Scotland is defo on the cards. Did a wicked trip to Tiree when we weren't allowed to travel overseas a few years back. Paradise. we even had sun for the whole week!
I have this same flooring and an install by the ply guys in my SWB T6 Kombi. It’s fantastic.
I drove up from Swindon, camped locally the night before going to the ply guys. I was at the workshop as they opened the next morning. Everything was installed before close of play.
Just seen this thread and im seriously thinking about plyguys myself.
Can i just confirm that the original kombi swuishy rubber floor is sufficient for sound deadening and insulation conpared to a strip out and dodo mat and insulation route.
Also how do the plyguys finish the edges of the flooring in the area of the door steps and tailgate step. I inagine that putting ply over the original floor will make quite a step.
Thanks. Dareen.
(Total newbee lots to learn)
Recommend it very highly.
Yes it is.
Well I haven’t tried the alternative approach but it’s a lot of hassle just to effectively replicate the excellent custom moulded thick rubber you’ve already got!! ‍♂️
Thanks. Dareen.
You just have a bit of extra depth the thickness of the ply floor. But it’s very nicely finished and rounded.
At the side door it’s shaped flush with the existing step and at the rear a small lip behind the plastic moulding.
I popped out and took pics of my side door and tailgate finish for you:
Yes it is.
Well I haven’t tried the alternative approach but it’s a lot of hassle just to effectively replicate the excellent custom moulded thick rubber you’ve already got!! ¯\_(ツ)_/¯
I’ll add my endorsement to what @AeonMach has said. My set up us pretty much identical.
Yes it is.
Hi mate I know this thread is a bit old but could I pick your brains a bit please. I'm thinking about in the buffalo ply down in my van but with a proper kitchen. Just looking at yours now I can see that it uses the anchor points as fixings just good because I wouldn't mind keeping them. Also I noticed if I have the floor permanently fixed down because the kitchen it doesn't look like the side step or rear plastic tailgate step can be removed. Is that the case?
Not quite sure I understand this and what you’re actually asking; not sure I understand what are statements and what are questions! Sorry 🤷‍♂️
I still have the tie down fixings but they aren’t actually used to fix down the ply floor; it’s screwed down I think…
Again not sure I understand what are statements and what are questions…
….but yes the floor is fixed down permanently and no the side step and plastic tailgate cannot be removed bc they are under the floor (although why would you want to remove them?)
If anyone is tempted to go down the route of fitting a ply guys floor...or any floor for that matter...over a padded kombi/ van floor I have a genuine padded floor for SWB for free in the classifieds thats really in my way they are welcome to have it !
Sorry to jump onto this post. I've been toying with the idea of designing my own furniture on CAD and sending it to be cut on a CNC machine. Once the ply floor is down, are the kitchen and bed units simply screwed into the floor or is there another method of securing the units? In particular the taller kitchen units (75cm). I can envisage screws pulling out of 12/18mm ply when cornering as the height and g-force could act as leverage. Or maybe I'm overthinking it? 🤯
Or I guess pronged tee nuts could be fitted to the underside of the ply floor and the units bolted down? 🤔
