Caravelle Storage help
nath1977
Hi
First time Caravelle owner. Got myself a nice 6.1 for our family of 3 children having moved up from a S-Max.
Couple of questions regarding storage as it appears less developed than the S-Max.
1. Am I missing a hidden compartment in the dash!? Where do you put coins, pens and other things without having to have it all on show?
2. The front seats have no built in storage yet a fair amount of space underneath if you avoid the wires. Any good solutions suggested - perhaps similar to the middle seats?
3. As there are no boxes or rails under the rear seats (removed after the T5?), are the Ikea Samla boxes the best way forward. Want to store jump leads, straps etc? I see there is a small compartment near side rear with the jack I can use too.
Any tips welcome.
Thank you!
You can get a glove box lid from here:
What about a box between the front seats like this:
I also have the storage boxes under my rear bench seat in my T6.1 Caravelle.
Like in this photo:
The actual storage boxes aren't present from T5.1 onwards - but the flappy covers should be there.
Also, some window luggage doodah's here:-
Like in this photo:
Thanks!
Just want to check I’m not going mad - I appear to have one of the front facing hatch doors used in the rear. Two of the rears clip on and off but the centre one appears to be a front hatch and therefore doesn’t clip on.
It seems like the previous owner may have broken/lost one then replaced it with the incorrect type.
Can someone confirm all three of the rear facing clip on doors are the same simple clip on type?
Sounds confusing but hopefully makes sense!
Here’s what I have if this is what you are meaning:
3 hinge up covers at the front of the bench seat, and 3 pull off covers at the rear of the bench seat.
