Carista - How I Done It -
But when I return home they don’t stay on as programmed by ticking the box for 20 or 30 seconds
Did you try flashing high-beam by pulling the stalk? Then opening the door should turn them on. On T6 they are not fully automatic.
Oh ok il try that thanks
So with engine on or off whist on the drive as i pull up ye
i thought it was time to update the Thread . .
2021 Update Pt:1
V5.5 Beta . .
scan for codes . . . . . i have 5x fault codes listed.
moving onto the service screen we have . .
new transmition data . .
over to the main tweek section . . .
this is a breakdown of what we have now . . . . these are the main section options.
this is now going into each setion 1 at a time.
1613745101716.png1613745108778.png1613745115362.png1613745121667.png1613745129292.png1613745136972.png1613745143128.png
pic limit . . . see prt 2
Have a look at Carista yourself . . .
Not sure, I think the only way to find out is to connect your veh and see. Worked "out of the box" for me.
I presume you had the coding already then for stock lights. I know they dont code as it would cause issues out the box, user is to code. Just watched THQ youtube video on it.
All I did was download the beta version, then connect to van - pulled up customise menu and found dipbeam remain on when main beam is on (I think that is what it said) - tested it and worked a treat. No coding done by me. My van is a 2016 T6 standard bulbs fitted from factory. I might change it back as think it might be an MOT failure!
Hi
I have already got the standard Carista app on my phone. I right in thinking I’ll have to delete it to download beta version, then log in again?
