Charging the ignition battery whilst connected to a T6
I used my oxford oximiser (similar battery charger for looking after my motorbike battery), but only to just make sure the battery is topped up after sitting for a while and doing local journeys. Put in a max of 0.85A through the cigarette lighter. It's not really a charger, it'll work as one but will take ages
Typically I read this post after having my battery on charge for 10 hours yesterday, connected directly to the battery terminals.
I don’t appear to have done any damage, the Ctek manual does show connecting it to the terminals unless charging a battery that’s inside the vehicle.
I don’t think there is one on a T6. There are 2 bolt heads just to the right of the battery on the wing, or the bolt which secures the battery holder at the base of the battery.
Pete
I connected the black wire to one of the bolts near the bonnet hinge. Seems to be okay.
My charger is 0.6Amps - so okay.
This is more of a theoretical question. If you were able to start the van with a jump start (or a Noco pack), how long would it take the alternator to charge the battery?
Is there any advantage to driving as opposed to just leaving the engine idling?
Just remember a 0.6A charger will take a long time to actually charge the battery, fine for a top up
If the battery was flat it would take approx 100 hours minimum to fully charge it !
I have charged it off the van from really low and it took three days 3 x 24 hours
time for a charger upgrade me thinks . . .
Dellmassive`s -- "how I Done It" -- Thread
Kit List And Stuff -- How I Done It & What I Use --
"how long would it take the alternator to charge the battery?" - The alternator could deliver 140A, but the battery would only accept a max of say 20A which would reduce as the battery SOC increases (due to internal resistance and battery chemistry).
Absortion time should be taken into account "C rate" , so you would still need to drive for 10 hours or more to fully charge a flat battery.
"Is there any advantage to driving as opposed to just leaving the engine idling?" - EU6/5 van with stop start have an energy management system that controls the alternator output and charge rate. . . . . so yes and no. The ECU will raise the RPM at standstill if a high demand is required, but the engine is more efficient at higher revs.
a 90Ah van battery would take a 5A charger 18hrs to charge fully (90ah / 20A = 18hrs (theoretical))
a 90Ah van battery would take a 10A charger 9hrs to charge fully (90ah / 10A = 9hrs (theoretical))
a 90Ah van battery would take a 20A charger 4.5hrs to charge fully (90ah / 20A = 4.5hrs (theoretical))
a 90Ah van battery would take a 0.6A charger 150hrs to charge fully (90ah / 10A = 150hrs (theoretical)) - that 6.25days or a week !!!!
have look here for more:
Battery Chargers - How I Did It -
Which Jump Starter?
Lithium Lifepo4 12v Batteries - - - Time For An Upgrade ? - - -
Battery Charging - Main Battery Earth Point -
Dc-dc Charger (for Leisure Battery) -- How I Done It --
Stop/start...regen...smart Alternator... Dc-dc Charger For Leisure Battery Or Not?
Battery Monitoring -- How I Done It --
