Chassis ground
Trekster
I am grounding my victron non isolated DC charger to the chassis ground. Should I use a bus bar between chassis ground and charger to allow me to use the factory chassis ground for both the charger and fuse box grounds? Or should I use 2 ground cables direct to the chassis ground (2 x16mm2 cables; charger and fuse box grounds sharing 1 factory chassis ground?)
Just connect both to the chassis
