Yes, that’s just coincidence.
The 105Ah is the amount of charge the battery can store. The 100A max discharge current the the maximum current that the battery can supply.
A simplistic analogy is if we imagine the battery full of charge (100Ah) is a watering can full of water. Then the max discharge current (100A) would be equivalent to how fast the water could be poured out of the watering can.
Ok so I had wired everything up including a sturdy ground behind the driver's seat as per recommendations. Everything had been working swimmingly for small runs close to home the past few days but on a longer drive where I plan to leave for some time trouble struck!
I am guessing from the quick search online I have a ground loop due to more than one ground though open to other ideas but that seems to indicate what it is from the below and online cursory search.
The charger was working fine from what I could see in the background when I turned my head back then all of a sudden there was like the noise of a bit of gravel hitting the van. Now it could have been coincidence but when I looked back the lights on the charger were out!
I kept looking back when I got a chance and no lights. I picked an opportunity to park and indeed the charger seemed dead! So I got out the trusty multimeter to try and diagnose. I checked both fuses to charger, both positive from starter and leisure battery, with a continuity test on either side of the fuse and there was continuity. Rest of the system still has power so not the main system fuse either.
Now here things narrow down a bit. I am really glad I installed that isolater switch between the starter and the charger now, having questioned if it was going to be redundant, as it has helped me narrow down the cause.
So I have a battery cutoff for the whole leisure battery system of which the charger is connected to the positive busbar. I switched that off and everything goes off as expected. Now for the unexpected...when I switch off the isolator between starter battery and charger my whole system is lighting up! Not just the charger which would not light up at all so far but everything, the solar charge controller and mt50, the charger. Also they light up but only for a seond in couple of second bursts then go off again, like a heartbeat.
So what is causing this and how do I stop it?
If I turn the starter isolator off things all go off again. I can switch the main isolator back on and the main circuits, apart from the charger which remains dead with no indicator lights which it usually would show before this, even if starter isolator was off, and seems to function normally. If I switch both off again and then the starter on and main off then the same 'heartbeat' of power to the whole system.
You guys said that I should make the second ground in habitation space for my leisure stuff but isn't this precisely what is likely causing the loop, having more than one ground to the chasis? Very ironic if so!
I do think it was good to make a new clean ground for my habitation gear but it seems to have brought more problems, which is exactly what I was trying to avoid in the first place by suggesting just one ground to chasis.
I don't yet know enough about grounds to know how to further troubleshoot so please advise.
I am going to have to cancel my planned trip now until I get this fixed as want to be back at base to have access to workshop and since charging would have been essential while away which effectively takes me out of action until it is resolved.
It may be a simple fix but I don't know that at this stage and so have to go back to get it sorted.
