I'm planning on fitting 8 led roof lights that will be switched from the leisure battery.
Ideally I would like the option to have 4 of them also come on when the doors are opened to replace the two current rocker lights that are fitted in the roof. I've had a look on travelvolts and can see a kit for running lights from 2 different circuits which I guess would have the option to have 4 of them run from either the leisure battery or the current lighting circuit but after using the search function here I can't find a definite answer.
In short if I buy a kit that allows two circuits to power the lights and use the current courtesy light circuit and the second from the leisure battery will it work? Also I assume the rocker switch that is built into the current courtesy lights would have to be replaced somehow in that circuit.
