Hello all, trying to do research across the forum into whether I can use a CTEK D250S Dual with my 18 plate bluemotion panel van to charge my non factory fitted leisure battery. Sifted thru just about every page of every thread on here but getting a little lost in what I should and should not be doing.
Is it true I can connect the D250S straight to the alternator or can i use a wire that is possibly under the double passenger seat?
If so do i connect it to the solar panel input on the charger or the alternator side?
Do i need to be using a relay so that the charger doesnt take power from the starter battery? Im not using a solar panel, just want the van to charge the leisure battery when the van is running.
if i can use this charger do i need to be earthing to the van or leisure battery? I came across a CTEK diagram that showed the charger earth needs to be to the van body and the battery. but dont want to be getting it wrong
Ideally would like to use the CTEK D250S as i got it off a friend to see if i can make use of it, but if i need to buy something more appropriate so be it.
any help very much appreciated thanks a lot
