Hi, please may I bring this back to ask for some assistance? I have a CTEK D250SA with a YUASA LB L36-100 and Sargent ac50 control unit and have recently purchased a 200W solar panel, Victron 75/15 MPPT and the IP65 smart shunt. I have created a wiring diagram attached after reading all the material on the forums here. Although, I am a little confused with the smart shunt wiring instructions, that displays the shunt wired to loads and chargers and not ground. I also plan to connect the aux cable from the smart shunt to the CTEK to monitor the starter battery. Which I am unsure if this will work? Or will I require a negative cable from the starter battery to the LB negative terminal?
Any advice would be greatly appreciated. Thank you.
My understanding:
Victron Instructions:
Starter battery connection:
My understanding:
