DAKU'S VAG CONTROLLER for PQ25
Do you know the software version of your previous T5.1 Instrument Cluster?
I still have the cluster it self
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
Component: KOMBI H04 0805 Serial number: 00000000000000
Coding: 160A01 Shop #: WSC 02737 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 353728FE15C3F6736C5-8060
On T6 Instrument Cluster, the functionality of all 4 LEDs (green & yellow for Front Assist & same 2 colours for Side Assist) have been removed.
Basically VW decided not to solder required LEDs and associated resistors.
Additionally the functionality of green LEDs (FRONT ASSIST & SIDE ASSIST) has been also removed from the software.
But thanks to @Daku's controller the functionality of these 2 green LEDs can be easily restored :cool:
  • Love
Reactions: mmi
Need tester for module for Car w/o Audio menu.
At bench menu works well.
Bench setup:
  • Gateway 7N0 BR - Not important 1)
  • 3AA920880H Color cluster - Not important
  • BCM 3AA937087E - Not important 1)
  • Radio - NONE
  • VAGPCB HW:1.X SW: D009 BETA (21-12-20)
1) PQ25 BCM have built-in Gateway into BCM.
Menu can disappear at first try, but after slide to menu again, it stay.
Looks like my charging works pretty well :whistle:
Ignition ON.
And engine ON.
Thank you so much Dawid for your amazing product and its endless capabilities :thumbsup:
I got question from Škoda owner, he want to enable GRA High via my PCB, i think that's possible but i must know messages.
Multilang feataure kick's IN !
All changes done by Coding via VCP.
Language bit is connected for DPF purging message and Live Data!
First photo, cluster w/o Polish characters - 3C0920817T / 3C8920870A
Available translations
C++:
 *     Języki
 *     PL    -     Polski
 *     EN    -    Angielski
 *     DE    -    Niemiecki
 *     RU    -    Rosyjski
 *     LT    -    Litewski
 *     IT    -    Włoski
 *     FR    -    Francuski
 *     RO    -    Rumuński
 *     LV    -    Łotewski
Can the module only be configured/update by vcds or is this also working with obdeleven?
VCP 100% working solution.
VCDS only for coding via helper - Little fixes to go.
Odis many bugs - work on it suspended for now.
obdeleven didn't have touch with it, they probably never add labels for it.
There's OE place but need some additional wiring to my module.
Front assist led
Side assist led
Position light led
Front Assist can be controlled as OE w/o additional wiring.
Rest of menu are avaialble via CAN only
