DAKU'S VAG CONTROLLER for PQ25
Only 2 layers :p, pcb have different color that i want l, i want black ! But no paint for it seller got :/.
V1.0 vs V1.1
Hmm i can said that 1.0 is fully dev version xD.
1.1 is 50% smaller than 1.0
Thinking about new design and do all controlled led via PWM, now only 2 of 4 was controlled via PWM.
Maybe i do it like gateway so i can avoid blinking icons and some flickering via bus.
Greetings,
Daku
V1.0 vs V1.1
Greetings,
Daku
Loving your work Daku. What's the MCU, ATmega809 or ATSAM32 or similar? I see the ATSAM D2Xs have built in 10 channels of PWM controller...
Let me know if you need and English language beta tester with his own soldering iron................ ;)
Have you tried to activate CH & LH menu, Do you think it’s possible??
What my pcb have to that ?? it's coding / eeprom issue in BAP modules.
DDP is too old and want too much amount of data.
That function isn't on my TODO list.
Convert BAP to DDP is easier than convet DDP to BAP.
No firmware/software modification to any existing controller is required.
This controller requires connection of 4 wires for its basic functionality:
[15] (after ignition +12V DC)
GND
Instrument Cluster CAN-H
Instrument Cluster CAN-L
I will post installation photos later on.
PQ25 version is still undergoing development
but if you want to get PQ35/46 controller just send direct message to @Daku and he will look after you :)
As promised a bit of overall explanation.
@Daku's controller can be installed in 2 different ways.
1. Externally to Instrument Cluster(effectively behind the IC)
This is definitely preferred way for less advanced users.
In this setup controller serves its functionality via CAN-BUS only
and available functionality is as follows:
- DPF regeneration indication via: LED, gong & text message
- additional Bluetooth icon
- engine & BCM data via AUDIO menu screen
- gear shift suggestion (not required for T6 engines)
- more to come
With this option the controller comes pre-wired with crimped connectors and appropriate plug/socket setup.
Basically 4 required wires need to be un-clipped from Instrument Cluster plug
and re-populated with provided ones.
+12V (red by @Daku) --> pin 31 (black by VW)
GND (black by @Daku ) --> pin 16 (brown by VW)
CAN-H (yellow by @Daku) --> pin 28 (orange/purple by VW)
CAN-L (brown by @Daku) --> pin 29 (orange/brown by VW)
Literally plug&play.
This is non invasive wiring methodology and can be reverted with no trace at any stage.
Installation example below.
20211017_174706.jpg20211017_175053.jpg20211017_175111.jpg20211017_175223.jpg20211017_175233.jpg20211017_175239.jpg20211017_182136.jpg20211017_182432.jpg20211017_182801.jpg20211017_183020.jpg
2. Inside of Instrument Cluster for more advanced users.
Controller serves its functionality via CAN-BUS(as described above)
and also allows to control FRONT ASSIST & SIDE ASSIST LEDs(both green ones).
There's OE place but need some additional wiring to my module.
Front assist led
Side assist led
Position light led
Front Assist can be controlled as OE w/o additional wiring.
Rest of menu are avaialble via CAN only
Probably found Oil level in milimeters :), some voltages.
Hello
I have been watching Roberts YouTube for a while now.
I have a t6 van and a t6 caravelle I would love to add the dpf regeneration function.
I have spare bcm and clocks
Can you help me please
Thanks Dave
Hi Robert.
I have sent daku a pm but not got a reply yet. Maybe he is busy or on holiday.
If you have his email address could you email him for me?
I hope to come over and see your bus soon. I am working in NI this weekend but I am flying, so will not have my van.
Thanks Dave
I installed the module today but i cant see the audio menu. I dont have original Radio. Do I have to activate something so that i can see the audio menu?
