There seems to be a wealth of knowledge here.. no suprises!
@Deaky, @andys Do you have any tips for getting the wheel off? I have a startline plastic wheel and want to put on a mfsw.. vagnostics have detailed the price to send me all the things (i'd prob get a wheel from them as im not sure what i ned to get them from ebay - plus i cant find airbags, you guys all seem to be swapping a highline for a flat bottom golf one so you can keep the airbags it seems?).
I think its a case of: battery -ve removed, wait 15mins. Turning the wheel 90, unclipping from the back, then 180 turn and doing the same. Remove airbag and unclip. Then undo the wheel and remove. But then im a bit lost - i need to install the retro fit loom between the slip ring and the BCM - but in which pins?
i can then code it all with obdeleven (in the post normally...)?
thanks in advance!
thanks in advance!
