A little more work on the hookup today. I’ve sent the original charger back. It was a 30a 3 output Victron charger. My original idea was to use it to charge my leisure battery and should I require it the starter battery too. I assumed that I’d be able to control the outputs using the Victron app. You can’t. Also, any batteries connected to it have to be the same type, you can’t charge an AGM starter and a lithium leisure battery. So I’ve brought 2 separate chargers a 4a and 15a Victron bluesmart IP65.
These have a much higher IP rating so I’m happy to fit these under the bonnet.
The 4 amp is for the starter, it’s smaller than the 15a and tucks nicely behind the battery.
I’ve fitted the leisure battery charger under the scuttle panel, there is loads of room under there and because the charger is IP65 rated, it doesn’t matter if it gets wet.
There is an earth point under the scuttle so I’ve connected the -ve outputs of both chargers to this and also added an earth bond from the consumer unit.
Because I now have two chargers I’ve added another breaker so I can switch them on independently.
I’ve drilled another hole into the van as the plenum grommet is full with the drain from the Hilo. The +ve for the leisure charger is fed through to the inside, ready for me to continue tomorrow..
