Do i need solar?
Thanks. That sounds a bit "once started - no going back" lots of problems. :eek:
So from the top surface of the pop top to the bottom of the void underneath it, I would need about 40mm.
Will have to see what I can work out at the weekend.
That will depend on you're panel...
Mine was around 35mm from the underside of the panel to the bottom of the rear gland with the radius of the cable.
