Hi all.
I have bought some vw puddle lights for my 2019 T6 and according to the instructions I need to connect the negative side, via a supplied relay to the brown switched negative wire on the door latch loom. The problem is the cable has a constant current so the light won't switch off when the door is closed. I checked the other cables in the loom and they all have permanent currents when the door is shut. Any ideas?
