When you go in to Carista and get the page that says force regen, keep looking at that page, after a short time the text will change and state the soot levelCan't see anything other than force a regen in carista, but VGA DPF worked....
I'll get the paid one and monitor it, I've have no idea what the levels for the soot mass should be, I'm assuming 6.5g is OK at the mo as it's just done a regen?
Makes sense as it’s the engine load that affects the exhaust temp’. Cruising on a motorway is probably the most fuel efficient journey possible.Ok - I ran the VAG DPF app with Carista and I have possibly got to the bottom of the frequent Re-gens.
Basically, (in my Van at least), passive re-gen is a myth!
You can't get the DPF hot enough to actually burn off the soot by driving the van.
I did a 55 mile motorway trip
Cruising at 70mph, 7th gear just shy of 2000rpm and the DPF was a steady 303 deg c - no where near hot enough.
I also ran at 60 for a while and no real difference.
All this time the filter was just slowly building up.
I did manage to get it to drop by one percent momentarily by flooring it, the temp shot up to almost 500 deg c, but then plummets back down when you back off.
After about 30 mins on the motorway, the Active re-gen kicked in when the filter was at 24g soot mass.
The Acitve re-gen got the temp up to well over 600 deg and slowly burnt the filter clear.
After 20 mins it turned off and the soot mass was back down to 5.5 grams.
So - no matter how much motorway driving I do - it doesn't actually clear the DPF - unless an Active regen kicks in.
This explains why the day after a long motorway trip the Active Regen will start.
I've no idea if this is normal - I was under the impression that driving it on A roads / Motorways caused a passive re-gen ?
Going to get in touch with VW and see - I have a suspicious wire that has been tapped off under the exhaust as well that needs looking at - might be related?
Thanks for the help and advice everyone.
Great, that's what I was hoping!I think you have miss-interpreted a lot of what you have read based on the above.
But your van is normal, so nothing to worry about. Just keep an eye on soot and let it regen when it wants to.
Ah, I thought passive was that the van had no part of it, it was just the natural heat from the exhaust.More time now and on PC
Under normal driving conditions your DPF will catch soot and the number will rise. I am not 100% on the passive, active and forced terms and their specifics either, but I'm sure someone will clarify.
My understanding:-
Passive regen is where you don't get much feedback so it should happen in the background, but the van is 'actively' doing something to make it happen. It is chucking more fuel in to get the DPF up to the 600C to burn the soot. Revs are high (1000 rpm at tick over) and fans stay on when you turn it off, and it stinks. No dash lights, unless you trigger this through Carista, or other. Happens at 30g on my van and down to 8g, so similar to yours.
When light comes on it means you should 'actively' take it for a drive at 2000+ rpm to enable it to complete regen. This happens when your van has not been able to complete the passive regens and soot levels are getting high. I think ~35-40g. However, I think the light goes out when the soot is below 30g (or 24g) in your case, so people think its done, but it isn't.
Forced regen is when the dealers get involved with software triggers cos the vans gone into limp mode due to too much soot build up. ~50g I think. Don't let it get to this stage.
There is plenty of info on here. Search for @mmi posts. There is detail about the different trigger levels, but it may also be software version related. I have the latest software on mine now, and it does seem to handle the whole regen thing better, like it doesn't seem to care about the fule tank being 1/4+ or about the van being hot, it just gets it done.
Soot builds up quicker in a cold engine or doing more low speed journeys.
Regens will occur every approx 150 miles at worst to about 300-400 miles at best depending on your driving conditions.
My driving distance between regenerations dropped down toRegens will occur every approx 150 miles at worst ...
