Blooming heck! That is one heck of P&P rate.Although - went through a pretend checkout and the sum went up to 552Zl = £110
Think that was just to make me feel better.
Sorry for late reply,, night time down here...I didn't have to change anything. Just plug in and run led light wire. Handy to be able to know how much soot is there, just by 1 press of button , then counting the bips...1 bip per gram. I am sure you will be happy with it.@Graham Jones
That took a few minutes to find.
Seems to be a niche product.
So - does it work ok with the default settings for you or did you have to change the beep thing? What engine have you got?
I checked, but it's not on the invoice. Will shoot them a message and checkReading back through your posts you mentioned the DPF wasn't getting hot enough when driving so wondering if that sensor was affected by the vehicle movement.
Did they give you a part number for the replacement sensor?
Great outcome and brilliant to see you posted back. Nice one.
Yeah I have always found this. From memory it will attempt regen twice for 15min periods and if it doesent complete it will give up. Revs go back down to normal etc. But when you set off again and go over 2000 revs it will kick back in to finish what it was doing.Noticed in the cold weather if I do a short journey then let it idle it and it's doing a regen after a while it's stops the regen but then when I go out again on a run it finishes it off. Is this normal ? Always finished the regen just don't know if the ECU knows it can't keep the temp in dpf at idle so waits til on a run?
Not sure. I had the van 18 months it's a 2017What year software do you have?
There was an update in late 2019 that may help.
Maybe ask VW if they can update. There are a few improvements but regen is way better.Not sure. I had the van 18 months it's a 2017
Or search on here how to find out. I can’t remember.Not sure. I had the van 18 months it's a 2017
