Cheers @LambethBoy
You might be able to save that!Sorry for jumping in on this thread but I had a right nightmare last week with my van and managed to let my van roll back with the drivers door open and hit the wall of my house pushing the door forward. As you can see from the pictures it had dropped a fair bit and (I think) bent the hinges. You can also see that the lower A pillar side of the hinge had moved so I unscrewed the bolt and with the help of the wife lifted it and re-tightened it. This aligned the door which stopped the striker catching on the lock when closing.
However, now I have to really pull the door hard to close it and when I open the door it flings open with force hence why I think the hinges may be bent. I have ordered a new upper and lower hinge and will change them.
I suppose what my question is, am I right in changing the hinges to see if this stops the door from flinging open?
I do have a video but I’m not sure how to upload it.
@LambethBoy @DellmassiveIt’s a good idea just to use a felt tip pen to mark around the front edge and tops of your latch so that when you move it you can see how much it’s travelled
Thanks @dellmassivThanks mate..! Loosened of striker latch earlier, didn’t realise I had to use ‘Substantial’ force to move it.
Will have another try tomorrow!
@Dellmassive @LambethBoyIt’s a good idea just to use a felt tip pen to mark around the front edge and tops of your latch so that when you move it you can see how much it’s travelled
@LambethBoy @Dellmassive Meant to attach photos = STRIKE PLATE and confirm STAR M8 2nd photo is the size head I need to undo? Tia Paul.@Dellmassive @LambethBoy
Gents, similar problem on Driver's door. When closing it bounces if you just let it closes naturally or even with a slam.
The only way to get it to close properly is to hang on to door and apply pressure until it is fully closed.
The lock on door appears fine. 2 click process engages as it should - same as passenger door which is ok.
To undo the striker plate I know you need a star head and mark original position! But how much pressure on screws? I note LambethBoy you did mention lots of power? Also did you move it up/down first?
It is still under warranty, but 40 miles round trip and having people inside my van prefer not if I can. Thanks as always. PAUL
Yes its definitely M8@LambethBoy @Dellmassive Meant to attach photos = STRIKE PLATE and confirm STAR M8 2nd photo is the size head I need to undo? Tia Paul.
I have this problem, door doest seem to shut unless you give it a firm push.@Dellmassive @LambethBoy
So I fitted the new lower door hinge today after giving it a quick spray of paint and it’s 99% better, luckily enough I didn’t need to change the top one although I did buy that as well. I’m chuffed to bits as I was worried I’d bent the actual door. I just need to fine tweek it now as it doesn’t quite close like the passenger one and I have to very gently pull it to close it properly. I’ve tried adjusting the Striker but it doesn’t seem to move any more, once the weather warms up I’ll give it another go.Sorry for jumping in on this thread but I had a right nightmare last week with my van and managed to let my van roll back with the drivers door open and hit the wall of my house pushing the door forward. As you can see from the pictures it had dropped a fair bit and (I think) bent the hinges. You can also see that the lower A pillar side of the hinge had moved so I unscrewed the bolt and with the help of the wife lifted it and re-tightened it. This aligned the door which stopped the striker catching on the lock when closing.
Thanks I tried that and it still "bounced" ... neighbour had a look and thinks it is the striking plate. Appreciate your thoughts and thanks you.I have this problem, door doest seem to shut unless you give it a firm push.
could be something to do with the air escape / pressure as if the windows are open its fine!
Then again when I insulated the van I removed the vw oem lower rear panels (with the holes in) insulated carpeted etc.
Try opening the opposite door before you close to see if that makes a difference.
Thanks Sam will have a look when my M8 bit Turns up in the post!I've adjusted my striker plate today and its as far in as it will go, the striker plate moves further back but the plate inside the frame wont actually go back any further. Still have a little play in the door.
Correct Ryan, bloody cold and just started snowing!So I’ve adjusted the striker and removed both screws as well but I don’t think it will move anymore I think the actual door hinge may need a little tweek, definitely a job for Warner weather.
Thank you @Dellmassive ... just waiting on my M8 bit to arrive and then I can play! Appreciate you always taking the time to help so many. Be in touch. Cheers Pauli have that issue when the additional rubber dust seals fitted.
sound deadening the doors help . . . . (more mass due to the weight and door close)
but I've also found that not all door seals are equal . . . and that some are stiffer, softer, thicker, thinner, rounder, squarer. etc etc than others.
and cutting the door seals down and just using strips helps. (ie just a vertical strip, compared to going all the way round the bottom)
if your door is bouncing . . . . . . first thing to do is remove the additional dust seal.
then test . . . .
Jesus, a 10mm gap. Even I would picked that up at my age!I’ve just remembered, there’s a metal plate (the plate can drop off) on the back, not nuts. If the plate is loose and the striker is moving then that’s probably your lot. My drivers door was about 10mm proud when I collected it brand new from the dealer, I could not believe they never picked it up on the PDI.
